Question about Goodman CLQ36AR49 Air Conditioner
I am getting hot air instead of cool air from my heat pump when it is in the cooling mode.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
The problem is in the thermostat wiring. Y1 on an air conditioner, brings on the cooling. On a heat pump, it brings on the compressor, which generally fails to heat mode. The O wire operates the reversing valve, which brings on cooling. If these wires are reversed, or not hooked up, you will not get cooling.
Posted on Jul 19, 2010
    Scholar:
  • 41 Answers
As a certified heat pump specialist, I can assure you there are many things that can cause it to run warm or hot in the cooling mode. You have provided insufficient data and information to troubleshoot here. Is the system NEWLY installed. If so. Was it working properly and then all of a sudden started blowing warm air? Previous response regarding the proper 24-volt wiring is one thing I would check. I've had several customers in years past whose pet dogs chewed through the thermostat wire leading to the outdoor unit - and wire nuts fixed the problem. I've also found stuck reversing valves - some were fixed by simply switching the thermostat from Cool to Heat approximately 20 times while others had to be totally replaced. I've also found several customers who simply only needed to change their return air filter, turn the system to Heat for 15 minutes to melt ICE accumulation on their indoor coils, then turn system back to Cool. And, I've found other customers who had either not enough or too much Freon in their system causing problems. So, those are the areas that I, personally, would check on my own heat pump system; and, in that order. Good luck.
Posted on Feb 14, 2015
    Problem Solver:
  • 12 Answers
Also check some units energize in heat some in a.c. if your system worked fine then started blowing heat you could have a bad heat sequencer causing electric heat to run. also the reversing valve in the condenser might have failed otherwise check your tstat and change "o" to "b"
Posted on Oct 30, 2014
Which wires do i put to together from a heat pump to make a straight cool
well the red and yellow will make it come on in cool , but if there isn't any selector for the reversing valve you'll need to add in the orange too , or it will only just blow air , but now some models don't have an orange , but instead just default to cool mode , when pwr isn't on the blue wire (heat)
Jan 18, 2017 | Heating & Cooling
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Ac outside unit of heat pump is blowing out warm air instead of cool.
if the indoor unit operate in cool mode the outdoor operate in heat and the absonant.i dont get the problem
May 05, 2010 | Heating & Cooling
Air condition not cooling
If this is a heat pump it sounds like the reversing valve is stuck in the heat mode, replacing it requires opening the sealed system, which needs to be done by a licensed ac repairman.
Apr 17, 2010 | Carrier 38CKC060 Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Goodman ac / heat pump
I just had a new unit installed and I am surfing for troubleshooting tips too. My unit is doing the same... cools well heat sucks. my problem has been isolated down to the reversing valve... It is constantly energised which means it is constantly in a/c mode even when kicking on the heat strips... We disconnected a line at the thermostat and it is working well as a heater now. You may want to check yours to see if it is actually kicking over into to heat mode... -rob
Nov 25, 2007 | Goodman CLQ36AR49 Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Goodman CLQ36AR49 Air Conditioner Logo
432 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
