Question about Craftsman 22" Gas Hedge Trimmer
Craftsman hedge trimmer won't start.
Trimmer quit running and I cvan't get it to start.
Replaced spark plug. Cleaned air filter. Carbarator looks clean. Put fuel in cylinder. Does not fire. Nothing works. Any ideas?
  • 63 Answers
Have you changed the H T lead and then check the cut of swicth for faulty wireing
Posted on Jul 24, 2010
Hedge trimmer , mod.040090D 40350. Won,t start.. I pulled the plug, grounded the plug body, a spark should be seen at the plug gap., but instead a spark is seen from the plug body to ground, what would...
You will see a spark jump from the plug body to ground if it isn't tightly grounded to the engine. However a spark should also jump the gap in the plug at the same time. It can be difficult to check a plug this way because it tends to bounce around the place when pull starting the engine. You could try getting a bit of wire and clipping on end to the exhaust or fin on the engine with a crocodile clip, clothes peg or vice grips. The other end of the wire could be wrapped around the threads of the plug and held with a clip.
Fore more tips on starting a hedge trimmer see:
http://fixofile.host56.com/tips2.html#tip2
Nov 24, 2011 | Craftsman 22" Gas Hedge Trimmer
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Aug 28, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Ght225 Weedeater hedge trimmer
try sanding the fly wheel and the coil to get the rust off
Jun 17, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Will not start
did you try the air filter. could be not getting air. And are you sure it is firing. if so try a spray of ether. You can but at auto parts store. but be careful with it. don't use much. If it is firing it will go.
Jun 06, 2009 | Craftsman 22" Gas Hedge Trimmer
Craftsman Hedge Trimmer model 358.796353 that won't operate
The problem you are experiencing is the coil. I had the same problem and confronted a freind that works on small engines. I asked him if the coil could be the problem and he gave me one to try out of another trimmer he had for parts. It is running well. The problem I now have is the blade tang that moves it back and forth broke. Now I'm trying to locate one of them.
Mar 28, 2009 | Craftsman 22" Gas Hedge Trimmer
Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Feb 16, 2009 | Craftsman Garden
Craftsman 22" Gas Hedge Trimmer Logo
784 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
