Hello i'm using Toshiba satellite L40 and the problem is my computer is not starting properly, i had to open my battery and put it again then it starts. please help me out, if i dont put off and in the battery again it wont even charges but when i do that my computer starts and charges also.
PABLOCSA
  • 1124 Answers
SOURCE: Toshiba Satellite 1800 laptop
Go to here:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
Posted on Oct 27, 2008
SOURCE: Toshiba Satellite A55-S306
Hi Sacnyc,
Very first thing, is send me the picture of your DC jack and adapter. I have repaired A55-S306 more than 10 times, and can replace your DC jack if its bad..
Posted on Dec 10, 2008
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite wireless switch doesn't turn on
Ok, if your using Vista, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please and thanks for using Fixya
Posted on Feb 13, 2009
Geekman
  • 32281 Answers
SOURCE: SATA DRIVER FOR install xp to Toshiba laptop
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
If you have problems slipstreaming you can during the first part of the XP install by pressing the F6 key to install a 3rd party driver for the hard disk. Windows will prompt you to press F6 so be ready.
Posted on Apr 05, 2009
SOURCE: "Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
I started having the same problem and worse mine would shut off without warning either from the battery running down or even just plugged in without a battery.
I thought It might be overheating so I got a can of air and cleaned all of the vents...and downloaded core temp to monitor the cpu temp @ http://www.alcpu.com/CoreTemp/. Same problem shut down and no charging even though it was running cool.
Finally I started changing settings and it seems to be working and charging just fine.
Here's the answer:
1. Set your power scheme to balanced
2. Open Toshiba Assistant from start
3. In Toshiba Assistant open CPU tab and set to low power.
4. When asked "restart now?" say no and shut it down using the start menu.
When you start it back up you will see the change.
Changing either one of these settings brings the problems back. I can't explain it.
I HOPE IT WORKS FOR YOU!
I just can't afford another laptop right now.
P.S. even at low power my system works fine...It's a little slower @ start-up but otherwise good.
Posted on Jul 29, 2009
Thoshi satellite L40 bios password reset
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch.
May 28, 2012 | Toshiba Satellite A105-S2071 Notebook...
How do i restore toshiba satellite pro L40 to factory ?
You can easily restore your laptop hard drive by using my partition recovery tool
Jan 15, 2012 | Toshiba Satellite L40 Laptop Universal AC...
I have a toshiba satellite A665-S6088 and today I have a message "plugged in but not charging" and the battery is not charging. What is this?
Hello, try these steps and see if it fixes your problem. First, shutdown your computer. Unplug it and take out the battery. Hold down the power button for thirty seconds. Also unplug the power outlet from the wall. Then plug it back in and put the battery in and turn it back on. See if that fixes your problem. Are you using a genuine Toshiba charger?
Thanks for using FixYa!
Jul 12, 2011 | Toshiba Satellite A665-S6086 Laptop
I cannot load the drivers for my TOSHIBA Satellite L40 model no. PSL48L-02H00Q, WHERE CAN I GET HE DRIVERS since i lost my CD'S..
Hello!
here is
a site that lets you scan your computer and automatically display the different systems drivers compatible.
Just launch detection and follow the instruction
http://www.touslesdrivers.com/index.php?v_page=29
thank you for choosing Fixya
May 23, 2011 | Computers & Internet
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Running XP on a Toshiba Satelite L40-18X
I Have satellite L40-18W-PSL4CE laptop . I installed XP . i got all drivers except sound driver. the last sound driver was running on vista is (Realtek High Definition Audio System Software Ver:R1.72) on toshiba site they said this driver soppurt vista & xp but i got nothing after installing the driver. pls help me with greatfull.
Sep 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite Pro L40 PSL43E Vista B to XP downgrade
i can find drivers for Toshiba Satellite Pro L40 PSL43E for XP too! Help mi plz. my model is PSL43E and i cant find this model in toshiba site:/
Apr 04, 2008 | Computers & Internet
Toshiba L 40 drivers
Go here: http://pc.toshiba-asia.com/support/downloads/index.jsp
Select "Notebook Computer" , "Satellite" , and them "L40"
Press the "Show Drivers" button
Dec 05, 2007 | Intel Frontier Design Dakota 24-Bit PCI...
Computers & Internet Logo
122 people viewed this question
Alun Cox
David Payne
David Payne
