Question about Danby (DAR604BLS) Refrigerator
Refrigerator section will not cool but freezer is ok
  • Danby Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorrefrigerator section will not cool but freezer is - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 19, 2010
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Model 596.72232200, s/n 10428892ap - top section stopped cooling, but the freezer (bottom) is OK.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 11, 2011 | Kenmore Refrigerators
NEFF K4663 fridge. the freezer works ok but refrigerator space does not go below 9deg C even at highest setting. have defrosted and water drain is clear.
The defrost board is not functioning properly.;
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Neff Refrigerators
Refrigerator section not cooling: >60F Freezer has been ok. No obstructions to air flow. diagnostic codes displayed are: Refrigerator ER and Freezer section DH Model: LRFC21755 please...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 28, 2010 | LG LRFC-21755 Bottom Freezer Refrigerator
Gibson/Frigidaire GRS20ZRH - Refrigerator section does not cool. Freezer cools OK. Water and ice dispenser is OK. Model is a side by side. Underneath coil/compressor section is clean. Please advise....
Check your fan that goes from the freezer to the refrigerator. It is probably faulty. If not then check your defrost timer.
I hope this helps
Please rate me
May 27, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have whirlpool refrigerator model# et9fhtxmq01 with the freezer section to the top and refrigerator section the bottom .The refrigerator section is not cooling and freezer section is not freezing ok.I...
Thaw it with a hairdryer and it'll work til you can get it fixed.
check defrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. If the heater and thermostat are ok it’ll be the control.
Sep 13, 2009 | Refrigerators
Danby (DAR604BLS) Refrigerator Logo
161 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
