Question about GE Refrigerators
1992 ge refrigerator not cooling, how do you check the freon levels or charge this refrigerator, top mounted refrigerator
  • 163 Answers
SOURCE: GE refrigerator TDX11SNYAWH.
check your defrost timer and see if it is stuck in defrost.
Posted on Mar 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Side by Side Refrigerator no longer cooling.
If not cooling or signs of not defrosting we will need to check the compressor start components, fan mortors and motherboard. Let me know and I can guide you through this. Sea Breeze
Posted on Apr 05, 2010
Testimonial: "Hi Sea Breez. I have ordered and replace the defrost heating element. I'll check the coils in a day or two. Thanks for providing the service manual!"
aasc
  • 1606 Answers
SOURCE: GE Top-Mount Refrigerator GTH22SHS, freon escape?
Even though technicians may wear a patch which says GE , is does not mean they are electronic refrigerator capable . Most probably know very little refrigerator repair .
From your description , it sounds like the 2 freezer thermistors could be bad . 1 is located on the freezer side panel inside a small oval housing . This thermistor tells the main control board , the actual freezer temp and when to cycle on / off . The second thermistor is located on the top of the coils , behind the inside rear freezer wall . This thermistor is " clipped " to the coils . Both are 1 " long , torpedo looking pieces , which you can easily replace ( only 2 wires to each ) . The thermistor on the coils , tell the main board the coil temperature and when to defrost .
The part number for both is WR55X10025 and cost about $10.00 each .
Posted on May 16, 2010
Testimonial: "Very helpful, three quick replies with helpful answers, knew part numbers. Thanks!!"
  • 1891 Answers
SOURCE: My Kenmore Top Mount Refrigerator Model 253 is not
clean the coils and make sure the fan's ( both) are working .. mm
Posted on Jul 03, 2010
  • 193 Answers
SOURCE: The unit will not cool
Without refrigeration gauges, you can't check your freon level. You have to check the pressure of the freon, not the level. If you are careful and have a basic knowledge of electricity and moving parts, you can get an idea if you are out of freon. If you remove the lower slotted cover from the refrigerator you will see the condensor coils. This is a radiator that has aluminum fins on the front and will have a fan running behind it. If the compressor is running this condenser coil should be hot to the touch at the top part of the aluminum fins. If the fins are covered with dust and dirt it can cause your cooler to malfunction. Also if the fan is not running the compressor will overheat and quit. If you pull the cooler away from the wall, you can see the compressor in the bottom of the cooler. There are two copper lines leading to the compressor. The small line goes to the condensor coils (the radiator) and should be hot enough to burn your finger if you have enough freon. Also the larger of the two copper lines brings the freon back to the compressor from inside the cooler. It should be cold to the touch if you have proper freon pressure. If both of those two lines feel about the same temperature, either the compressor is not running or you have no freon. BE CAREFUL! There are electrical lines and moving fan blades near the compressor, and some of the tubing gets really hot.
Posted on Sep 23, 2010
Testimonial: "Thank you very much. Excellent advice!"
The freezer works fine, refrigerator section not cooling it is 6 yrs. old, should it need a refrigerant(freon) charge ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 09, 2010 | GE GSL25JFPBS Side by Side Refrigerator
My regrigerator (GE Profile) is not cold on the fridge side, but ok on the freezer side. I found ice buildup in the freezer so I defrosted and dryed it completely, cleaned it- including coils...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 16, 2010 | GE Refrigerators
How do mi check the freon
Refrigerators don't need freon added to them unless there is a leak and until you find and repair the leak you have not fixed the problem.
A lot of people think when their refrigerator is not cooling that they need to add freon. This is not normally the case 99% of the time. You are a lot more likely to have a defrost problem or a fan problem if your refrigerator is not cooling.
If you actually do need freon, call a reputable professional. There are a lot of guys out there that will just add freon because you told them it needed it, charge the heck out of you and then leave. Be careful about telling some jack leg that you need freon.
Jun 27, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
May 15, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
GE side by side Not freezing or cooling at the top levels
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
rtyhrtgf
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The noise appears that is comming from the black ball shaped (compressor) up to the right side in front of a cooling fan. when it starts it is load then it drops the noise level a bit, and it stays like...
This indicates that the compressor is overloading. Maybe due to low freon, or the compressor itself is defective. Loud compressors indicate the system is not having enough charge. You can try charging it using a line tap available at most ac supply. Then you can use a retro fit and charge it with 134. Refrigerators use the same kind of freon as cars.
Jan 23, 2010 | GE Monogram Side by Side Refrigerator
GE model TFX24JAX side by side seems to run bt
Good day,
Either the refrigerant charge was lost, or the compressor will not run.
Remove the back bottom cover, and see if you hear the compressor running.
If not, you can remove the start components mounted on the side of the compressor. take them to an appliance parts house and have them tested. They include a start relay, overload protector, and on some models a start/run capacitor.
If they check O.K. then you're in serious trouble with the machine.
P.S. Freon is a gas. It doesn't leak onto the floor, just evaporates into the air.
Dec 15, 2009 | GE Refrigerators
GE not cooling properly
If you have changed temp and adjusted vents, then either your temp sensor may be faulty or thermostat itself may be faulty. Check compressor to make sure it is pumping and there is no freon leaks.
Jul 09, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator and freezer cools at bottom, but not at top.
first thing to check for is your fan running if yes than does your freezer freeze enouht to freeze water if not you need more gas or should i say freon possible freon leak thanks from gilles
Jan 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
