Question about KitchenAid Refrigerators
I moved a perfectly working KitchenAid fridge from inside the house to the garage and now it blows the ground fault breaker the second it is plugged in.
  • KitchenAid Master
  • 909 Answers
Almost definately, there is a wire or more accidently pulled loose while carrying the fridge.Check where the cable enters the fridge and the surrounding area.
Posted on Jul 19, 2010
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
Amana refrigerator trips breaker
your compressor is bad its drawing whats called locked rotor amps you can buy a hard start kit at your local hvac supply house which will be a plug in fix make sure you read the instructions
Feb 12, 2012 | Amana Refrigerators
Fridge blowing breaker
Try plugging it in somewhere else with nothing else on that breaker. No extension cords. My air compresser sometimes does the same thing due to a large power draw.
Oct 04, 2009 | Maytag MFD2560HES Bottom Freezer French...
High voltage
Great, JP. Could I ask you to please rate my assistance. Thanks very much!
Charlie
Aug 20, 2009 | Coleman Powermate Powermate 5000W...
Kitchen Aid range Breaker always tripping ERROR F5:E3
The elements or a hot wire feeding the control switches has been bumped and is grounded. You can probably find it with a thorough visual inspection. Look very close at the wiring and look for something pinched or touching metal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Fridge not cooling
Make sure coils underneath or backside are clean of dirt. Make sure compressor is humming when running. You can tell by moving fridge out and it will be at the back side of the opening on the bottom side of fridge. It will be about the size of a soccer ball. If it has a little of vibration and might be alittle warm to touch. Also open door and make light comes on inside. In newer homes these days they are using ground fault interceptors. Even tho this one is not plugged into one that has the resetable breaker check other walls for one that does have the little red and black push buttons. They sometimes wire some into one ground fault, when that pops, it shuts power to the others. Our house is that way, I have to go to our bathroom and reset it to make the ones in the kitchen work.
Nov 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
77 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
