Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
BOTTOM PART IS FREEZING TOP PART IS HOT - Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
  • greginato200 Jul 20, 2010
    fan working fine , change capacitor ,defrost ice inside freezer in the bottom part, wait for a couple of days then start,but still having same problem
  • Maytag Master
  • 909 Answers
You evaporator fan motor is stuck. Very possibly ice build up causing the fan to stop. Either defrost for about 12 hours or strip and defrost ice with a hairdrier. I suggest natural defrost.
Posted on Jul 19, 2010
Bottom of freezer freezing bottom of frig cooling top of freezer and top of frig not cooling or freezing
I'm thinking you have a Bad fan. Not circulating air? You should hear the fan running when you open the door.
Feb 13, 2018 | Refrigerators
Hot on top, cold on the bottom on both sides
Mine did the same thing and the circuit board that controls the fans had gone bad . It could be that or the fan itself.
Jun 06, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Fridge is way to cold--is freezing the vegetables, even when I turn it down. Floor is hot under it, side by freezer is hot too.
sounds like the cold control that adjusts the temperature is bad,the ho on the under and sides is o.k. it tells you the compressor is running good,this is the hot refrigerant going thru the condenser at the bottom and sides
Jul 29, 2010 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
Dec 09, 2009 | Whirlpool 14.8 cu. ft. Chest Freezer...
Top refrigerator not ccoling and bottom freezer
check the condenser temperature when the compressor is running by hand it must be warm or hot if it is not then that means no refrigerant left in the system.This can be a possible cause.
Sep 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Top of the freezer not freezing
SealedSystem problem. You need a "Certified Technician".
Apr 26, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
FFA70
these machines commonly do not defrost sometimes an intermittant fault
remove back panel from freezer and if im right, the pipework will be iced up especially at the top. de-ice carefully with a hairdryer but don't blow hot air on the stats mounted on the pipework. turn on and check fan runs as well
Jun 29, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
57 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
