Question about Panasonic Audio Players & Recorders
Panasonic XBS table-top radio: Can't get the time to show
Panasonic XBS radio: I reset the clock, but don'tknow how to make the time setting remain visible. When I have reset it, and remove my fingers from the time-set buttons, they stop showing the time and the space is filled with dashes. When I push the button again, the time I set is shown. How can I keep the time setting showing all the time, except when I change the station?
  • 5 Answers
SOURCE: Push the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
Posted on Mar 13, 2009
escapement
  • 2338 Answers
SOURCE: Set time on Touch Screen Thermo Clock
Did you notice that this is TOUCH SCREEN? This is why you have just one resetting button. All the settings must be done using TOUCH SCREEN. So, Tap on appropriate icons on the screen and play with them till you find the right settings.
Unfortunately there is no instruction downloads available on the net, so, you have to find the way around yourself.
Rate me, please.
Posted on Mar 21, 2009
SOURCE: Manual Information/Owner Guide
In order to toggle display of Temperature, Seconds, Day of Week, and Month, hold + and press Set once. Release and repeat to move through the various display configurations.
Posted on Apr 07, 2009
ybchuan
  • 201 Answers
SOURCE: CANNOT RESET CLOCK
1) Press SOURCE and hold it until the unit turns off.
2) Press AUDIO and hold until clock appears in the display.
3) Press AUDIO again to display the setting u need to configure.
- when u found clock, press < or > to select the segment of the clock display you wish to set.
- press /\ or \/ to set the clock.
- press BAND or hold AUDIO when finish.
YBC (/\)
Posted on Sep 08, 2009
SOURCE: I can't set the time, the alarm time, or do anything of that sort
AHAH! I had this problem also, so i tried google and it led me here. Luckily, I kept trying and figured it out so I will share my knowledge with you although you may have found it out already...
First, make sure the radio and ipod are off and it's in clock display mode.
Then, click and hold "alm set" while clicking the left "timer set" arrow to set the hour of your alarm and the right "timer set" arrow to set minutes for your alarm.
Then click "alm on/off" to turn it on and off.
Posted on Oct 19, 2009
How do you set the time and alarm?
Do a Google search with the Panasonic model number and manual.
Jun 23, 2015 | Audio Players & Recorders
How I set the time on the radio?
Depends on the radio.
General idea is this:
turn radio power off on face of radio. Clock should show.
push button such as SET / CLOCK / TIME
push other button HOUR MIN up down seek scan ff rew (one button will control hour other button will control minute)
turn radio power back on. clock should remain set.
Dec 06, 2014 | 1993 Buick LeSabre
Sony XDR-C705DAB wont set time
please press all buttons at a time it will reset
Nov 24, 2013 | Sony Dual-Alarm AM/FM Clock Radio with...
How to set the time on Centrios atomic clock?
I had the same issue. This s a great clock radio, but not very intuitive. I've uploaded a PDF of the manual from my clock radio, I hope it is useful.
Nov 30, 2012 | Centrios Audio Players & Recorders
Panasonic clock radio RC-6099 How to set the time
1. Press and hold button on top front marked: "Time Set" (also has "OFF" above it) 2. Using LHS buttons to go forward or reverse as marked press and hold until correct time is displayed. Middle button here will move it fast then release and use single button when closer. To set alarms either the Alarm 1 or 2 (also marked "Display/Adjust" held down while using the side buttons as before.
Oct 24, 2012 | Panasonic RC-6099 Clock Radio
Clock wont set on Panasonic DMR-EZ48V
set time & date.try change memory ic or" repogram for reset the machine.
May 30, 2012 | Panasonic Televison & Video
How do I set my clock on my accurian table top hd radio?
1. Turn on the radio
2. Hold down the "Clock" button. It will switch to clock-date setting mode.
3. Use the "Tun-" and "Tun+" buttons to adjust each field.
4. When one field is set, push the "Clock" button to get to the next one, and when all are set push it again to exit.
Aug 21, 2011 | Radio Shack "Accurian" Tabletop HD Radio...
How do i change the time?
Hello, here is the instructions for setting the clock
RDS Clock Time Broadcasters can choose to send clock time information in the RDS data. This information can be used to update the clock time on the radio. RDS clock time is broadcasted once a minute. To set the clock using RDS clock data perform the following:
• Press and hold the HR and MIN buttons together for two or more seconds to update the time.
• The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
if this doesnt work, just simply push and hold the hr and minute buttons to set the time
• Press and hold the HR and MIN buttons together for two or more seconds to update the time. • The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
Oct 23, 2010 | 2002 Chevrolet Impala
Sony clock radio with auto time set is always 4 minutes fast.
This is easily fixed. Set the time manually the 1st time. Make sure you use the CORRECT time, which is four minutes less than what the clock said when you first plugged it in. Once you reset the timing, it will remember the four minute difference and always show the correct time.
Sep 11, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
67 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
