Question about Kohler Fairfax Single Control Lavatory Faucet Lever Handle w/ Pop-up Drain
Fix cloudy tap water
How can I remove cloudy tap water?
    Sergeant:
  • 200 Answers
Install a screw on filter to keep it clean.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
Why when I turn the hot taps on I get milky water out of the hot taps and its a new HWS Vulcan 250 lit electric single element only 3 months old
Put that water in a glass and let it sit for a couple of hours. If it clears up, it is air bubbles. The old unit most likely had mineral deposits on the elements and they insulated the water from micro heating that creates the bubble. Since the unit is new, the water is in direct contact with the heating elements and micro bubbles are forming on the elements. When you turn the hot water on, the turbulence washes the bubbles out.
Sep 04, 2016 | Water Water Heaters
Hi, I have a question
Hello Kiran - Often cloudy water is caused because the water was not purged. Try purging the water lines by running water through the filter for a total of 3 minutes. This can be done either in one big bucket or in various cups. If the water remains cloudy, then I highly suggest verifying that the filter is in good conditions with no cracks or damages. If the filter is working, then I recommend checking your tap water. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have an issue within the refrigerator lines.
Jun 16, 2013 | Frigidaire PureSource2 Water Filter WF2CB
Can you put treated tap water in a water cooler?
HI.UMMM WELL i would think is not a problem but normally tap water has fluoride and clorine which gives a bitter tate and cloudy water.sooooou. u make your mind up...plus the ready bottle is sealed as well as one way ticket in and out.good luck hope this helps ali
Jul 09, 2012 | Hamilton Beach Water Cooler with Storage...
I amgetting rust marks on my cutlery and my glasses are cloudy
It could be low water fill but more than likely a failing watersoftner try some Lemmeshine at walmart. to remove cloudy issues and don't add more soap trying to make up for the cloudiness on glassware it will only make things worse.
Apr 01, 2011 | Hotpoint Dishwashers
Our Maytag MDB9100AWB is 5 years old. Have had repairman out several times. Problem is a light cloudy scum on everything. He has replaced several items, has had us clean parts and fixtures, etc and even...
There are three typical causes of chronic cloudiness on glassware/dishes.
  1. The incoming water may be too hot. Make sure the water is at or below 140 degrees F.
  2. Test to see if cloudiness is removable by hand cleaning or soaking for 5 minutes in white vinegar. If it is removable, it's due to hard water. Use a good quality detergent, and match the amount of detergent used to the water hardness and use a rinse aid. (Some low quality detergents clean poorly and leave a film.)
  3. Glassware may be etched, due to too much detergent, too high water temperature, or pre-washing. Etching is not reversible, so it's important to correct the problem promptly.
Hopefully these hints will help you to home in on the problem.
Dec 27, 2010 | Maytag MDB9100A Dishwasher
Glasses and others things are not getting clean in the upper rack. A white film remains on the glass and stains are not removed. Also I'm having trouble with the silverware showing rust spots and not...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Other things to try: CLR on the spray nozzles to loosen up cloggs.Check the filters to be sure they are clear.
Jul 30, 2010 | Jenn-Air 24 in. JDB1270AW Built-in...
Last three loads have not cleaned my glasses - cloudy and lipstick still on them. Using JetDry and Cascade powder. What can I do to fix this?
You probably have a soap buildup. Try running it without any dishes in it. Let it fill up and start washing a few minutes, the open the door and see if there are suds. If there is, pour a half cup of cooking oil into the water and let it complete the cycle. That will clear the soap buildup. Aside from that, keep using jetdry and make sur the water going into the dishwasher is hot (run kitchen tap until it's hot before starting dishwasher to clear the line)
Mar 28, 2010 | Dishwashers
Clear glass dishes are cloudy. What is causing it? We have checked the arms--they seem to be working fine. Some days it does better than others--today they were extremely cloudy. I washed the glasses by...
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is due to hard water deposits; make sure the salt reservoir is topped up. Do not worry about over-filling it.
If the cloudiness is not removed, it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. Dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Dec 17, 2009 | Dishwashers
Dishes suddenly are coming out cloudy (mineral spots?) even though we use the rinse agent products. can something else cause this?
heater may not be comming on . ck it / low water tempt will cause this / bad dertg will also do this .. ck the washarm holes they must be clear ( open ) .run tap till hot then start dw / ck drain to disposal it should have drain loop to prevent back up / this will smell bad and make dishes cloudy . / hop these will help .. mm
Dec 03, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kohler Fairfax Single Control Lavatory Faucet Lever Handle w/ Pop-up Drain Logo
212 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
