Question about Creda 24 in. DWI34 Built-in Dishwasher
I have a credaplan integrated dishwasher with no manual it came with the house so is about 15-20 years old. I want to put salt in it. I have found a compartment with an 's' on it but just want to be sure that this is the right place. I have never owned a dishwasher before. Thanks in advance for your help.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
When you openbyhe compartment it should be full of water, this is where the salt goes. Having never owned one before, make sure you only us granular dishwasher salt, never table or rock salt
Posted on Jan 06, 2018
  • 1462 Answers
SOURCE: Creda plan Integrated Dishwasher fault
door latch is in wrong position, split the door so you can see whats what and change the position of the switch
Posted on May 18, 2007
COXY
  • 76 Answers
SOURCE: SMEG INTEGRATED DISHWASHER FLOODING
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Posted on Nov 18, 2007
bigg t
  • 640 Answers
SOURCE: miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Posted on Jan 06, 2008
SOURCE: where to add the salt
I have just moved in to a property with a miele dishwasher model no. G1220SCU. I have not been able to locate a manual and it also requires salt to be added
Posted on Aug 14, 2009
57 varieties
  • 1653 Answers
SOURCE: I put powder detergent in salt compartment in my
Scoop out as much as you can and the fill the compartment with warm water until it forces as much detergent out as possible out and then repalce the cover and run the drain cycle on the machine. The fill the salt compartmwnt with warm water a further 2 or 3 times to get rid of most of it if not all of it and drain. When completed then fill the compartment with salt.
Posted on Nov 13, 2009
Testimonial: "Thank you very much for your prompt response. Will try straight away, fingers cross!"
Salt holder full of water
Hi Elizabeth
have had a dishwasher for many years and have found this to be a normal practice .... Hope this puts your mind at rest ????
Mar 20, 2016 | Dishwashers
Where do I put salt.
Your question about Dishwashers "Where do I put salt" is quite myterious. I never heared about need to put salt in dishwashers. In any case, please specify the model and make of your dishwasher or other device which needs to add salt to get it working, and maybe someone might help to get a downloadable version or give you a clue how to get your manual.
Apr 25, 2015 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Where do i put the salt in my hotpoint dishwasher ?
If you don't put salt in the appliance then the regeneration crystals will clump together over time and solidify. This will cause a restriction in the softener unit.
If you stopped using it and then started again you may find that the impurities caught by the crystals have simply found their way into the appliance.
You can set the softener to be at minimum setting if you are in a soft water area.
The salt isn't used to soften the water, it's used to clean the crystals in the water softener unit.
Why Do I Need to Use Salt in my Dishwasher?
Salt is needed to ensure that your dishwasher's in-built water softener gives an optimum performance. You will especially need to use dishwasher specific salt if you live in a hard water area. You can purchase one of our Aqua test strips (part number 180876) to determine the hardness of your water from our parts and accessories store or call us on 08448 225 225 .
Manually drain the floor of the machine, put in salt, and check out.
open the salt container at the bottom, and it will be full up with water, and it really will smell bad. clean it and add salt near to 1kg. then run run a prewash cycle and then check out does the salt error is coming up.if yes then more salt needs to be added.
This will help. Thanks please keep updated. please do rate the solution positively.thank you for using fixya
Mar 17, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
Hello. My dishwasher has been pretty perfect for four years. When my house water softener ran out of salt, I added rinse aid and salt to the dishwasher for the first time. I subsequently added salt to the...
Try cleaning the machine by adding white vinegar to the wash water (before the water-fill procedure finishes). Put your stained dishes and cutlery in with the wash to remove the hard water deposits. The combination of salt and rinse aid may have helped cause this problem. Hope this helps!
Feb 11, 2010 | Dishwashers
Nov 18, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
May 16, 2007 | Creda 24 in. DWI34 Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Creda Dishwashers Experts
myrlanthian
Paula Hamilton
Colin
Are you a Creda Dishwasher Expert? Answer questions, earn points and help others
