I have a wireless router (D-link). Frecuently shutdown my internet connection (just wireless) If I use one of the 4 ports (wired) everything works fine. Do you have an idea? Thanks in advance.
  • 61 Answers
Try been closer to the router you could be just out of range
Posted on Apr 21, 2008
Hello, I am currnetly using a Belkin ADSL2+ modem with wireless G Router and have just been given a D-Link Dir-855 Xtreme N Duo router I wish to use and have been told I can buy a ADSL Modem only to...
I think there is no need to replace the ADSL2+ Router.
Belkin is fine and should work well in combination with the D-Link Router and you would get the downlink data rate up to 300Mbps.
I recommended that you use Belkin Router as ADSL Modem and Dlink to provide wireless access. (Instead of buying ADSL Modem)
So, all you have to do is : -
-Turn-off wireless signal of the Belkin modem.
-Connect the Dlink Router to the Modem (Belkin) through CAT6 Cable.
-Configure the Dlink Router, Secure it and Enjoy 300Mbps Data Rate.
(In this way your Belkin will serve as ADSL Modem and Dlink would be the wireless router)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
May 09, 2011 | D-Link Xtreme N Wireless-N Gigabit Router...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
HVING PROBLEM ACESSING THE INTERNET THROUGH THE ROUTER . WIRELESS OR HARD WIRED . IFI RUN STRAIT FROM MODEM I HAVE INTERNET . ONCE CONNECTED TO ROUTER I DONT
connect the router wan port to one of the modems lan ports,
then connect to the router per lan or wlan and everything works.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
The problem is that after one year, the wireless connection does not work. My laptop finds the network, but it does not receive anything.
Try to reboot everything and make sure that cables are properly intact from the modem to the WAN or Internet port on the router
Mar 18, 2010 | D-Link / RangeBooster N 650 / DIR-635 /...
I am wanting to run my (currently wired) laptop to be wireless (have bought a USB adaptor to do this), but also keep my main PC wired. I clearly need the internet on my PC to set up my DLink G ADSL2+. I...
You will need a wireless router with a built in switch. Most of them these days will have a built in switch. Here is a picture detailing what I am talking about.
You're internet connection goes into the ADSL port. Now, it will be broadcast WIRELESSLY through the antenna to your laptop. With this example, you could connect 4 more WIRED computers through the LAN ports. The built in switch is the division of the connection into the separate LAN ports.
I trust that this will help you greatly and look forward to your response!
Feb 26, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
HOW DO I CONNECT DIR165 TO PS3 I HAVE ENTERED THE LAN AND ALL THE OTHER ADDRESSES BUT IT WONT CONNECT
The D-link Router should work with its "factory" settings,
with most ISPs (Internet Service Providers), if you connect your
cable-modem or ADSL-modem to the 'WAN' or 'INTERNET' port on the router, and if you use an Ethernet cable to connect from one of the 4 'LAN' ports to the network-port on your desktop/notebook computer.
Once you have established a "wired" connection, and you can surf the Internet, follow the instructions in the manual that came with the D-Link to run the "Wireless Setup Wizard" to configure the "wireless" part of the router.
Add those "wireless" settings into your PS3.
Dec 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
D-Link DI-524 4 Port connection Problem.
Perhaps the router is not broadcasting its SSID, therefore is invisible to would be tappers. Type 192.168.0.1 into a browser on a computer directly wired to the router, leave the username blank, if you havent changed it, the password is admin by default. Once logged in check that wireless is enabled and that you are broadcasting the ssid, you may want to setup/change security settings for the wireless connection at this time also.
Feb 11, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
