Question about Refrigerators
I have a kirby compressor on my coolroom - how do I set the thermostat on the refrigerator
2 Suggested Answers
SOURCE: traulsen refrigerator fans power up but not compressor after 12 month storage
either the tstat or the starter pack is bad - I'd start off by replacing the starter pack with a all in one type. 1/3 horse size by supco. should have it at your local parts store.
Posted on Jan 04, 2015
Beverage-air DW freezes
Try turning thermostat knob all the way to left or counter clockwise. This should shut the compressor off. If the compressor continues to run the thermostat is stuck closed & bad. If the compressor remains off with thermostat turned all the way to the left try turning it slightly to the right (warmest setting). See if it stops freezing. If it continues to freeze set at warmest setting replace the thermostat. Try pricing a thermostat out at Refrigeration Hardware. Link attached. Refrigeration Hardware Supply
Oct 05, 2013 | Beverage Air Refrigeration Deep Well...
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Refrigerator getting to cold , thermostats at mid-range. Technician said thermostats faulty , i don't share that view .Before this refrigerator condenser was changed due to a leak & corrosion on it,...
The thermostat is the only thing that turns the compressor on and off with temperature.
Turn the thermostat to its lowest setting and see if the compressor turns off.
If not,the thermostat is bad.
Feb 21, 2011 | Refrigerators
Freezer works fine but the fridge wont go below 10 degrees
Please check your thermostat and compressor. 1. Thermostat You need to set thermostat correctly. Put the set at middle or a bit colder. 2. Compressor. - You may have insufficient refrigerant - Low oil - Dirty evaporator.
Please observe both items above and get them fixed.
Dec 14, 2010 | Refrigerators
My compressor runs but I think it shuts off and stays off too long...the box gets to warm and the ice starts to melt before it starts again
First of all, before you do anything, clean the coils under the refrigerator. I couldn't tell you how many refrigerators I've 'fixed' that needed nothing more than the coils cleaned. Dirty coils can cause a multitude of problems, many of them with the exact same symptoms that would be expected when refrigerant components fail. Dirt is the #1 enemy of any refrigeration unit.
If that doesn't help, since both sides of the refrigerator get warm before the compressor kicks back on, I'd suspect the fresh food temperature control thermostat. Not an easy fix for the average homeowner unless you've got specific skills in appliance repair.
Before you do anything, try this. Turn the fresh food thermostat all the way up, the set the freezer setting at a higher than normal setting. The way the system works is that the fresh food thermometer turns the compressor on and off and the freezer control simply controls how much of the cold air from the freezer is diverted to the fresh food compartment.
If you turn the fresh food thermostat higher, the compressor will run longer and adjusting the freezer control to a higher setting will allow less cold air into the fresh food compartment, forcing the compressor to run longer in order to cool it to the thermostat setting.
If the settings have to be abnormally high, this is a workaround, rather than a fix. To get a permanent fix, you'll probably have to replace the fresh food control thermostat.
I hope this was helpful to you or to anyone reading it.
Oct 10, 2009 | Amana Refrigerators
Kenmore refrigerator seemingly runs all the time. Defrost cycle must be working, because I find no frost on the evaporator. On a setting of 3, the recommended setting, the refrigerator is 40 degrees, the...
Yes you are right the thermostat is not responding to switch off the compressor at the desired temperature setting. It stay "always on" position. Replace the thermostat to rectify this problem....................sodeep
PS: low refrigerant gas could also contribute to aggravate this problem, so have it checked too by the repairman.
Aug 06, 2009 | Refrigerators
Paragon 8145-20 defrost timer
I am not professional at commercial refrigeration, and can't answer your question directly.
However, you can see 8145-20 240V defrost timer wiring diagrams and manuals on following link.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145 timer is time initiated, and pressure/temperature terminated, with back-up time termination.
Jun 28, 2009 | Paragon 8145-20 Defrost Timer
Refrig. not cooling, but freezer working fine
Is there ice frosted on the back wall? If so you have a defrost problem and you need to replace the thermostat, Defrost timer and heater. This ensures the problem is totally fixed. if you can nail down exactly which of these parts is the problem then just replace the problem.
Feb 09, 2009 | Frigidaire Refrigerators
Have bought desmon coolroom FRI171723 BUT mislaid instruction manual
have bought desmon coolroom fri171723 but mislaid instruction manual
Nov 04, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
