Question about Kenmore Freezers
Kenmore model 106.8262110 runs ,not staying cold . It is defrosted , it will get cold but does not seem to run again
5 Suggested Answers
  • 323 Answers
SOURCE: Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Posted on May 12, 2009
  • 1230 Answers
SOURCE: True freezer model TS49f-RC. Evaporator fans will
You are most likely correct. Most manufacturers of freezers have fan delay/defrost terminators. But keep in mind that if the box is hot, it will not stay in defrost as that is what the terminator is designed to do. Does the unit ever get cold? You may have a refrigeration problem and the terminator is good. If you can give some additional info, I'll be glad to keep assisting you to get it going.
Posted on Nov 24, 2009
shastalaker7
  • 1515 Answers
SOURCE: true model gdim-26. runs fine unitl defrost then
Hi, sounds like your defrost clock is stuck in the defrost mode. On most true boxes they have a paragon defrost clock with adjustable pins you can set the amount of cycles and duration of the defrost cycle. Find the clock and give it a turn in the direction of the arrow or cw. It will come out of defrost and start to freeze again. If it continues, you may need a new clock. Let me know what you find. Keep me posted. True boxes are top of the line
Sincerely,
Shastalaker7
Posted on Mar 24, 2010
heatman101
  • 43501 Answers
SOURCE: Mdle 21571 upright Kenmore Freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 02, 2011
Kenmore upright freezer does not shut off until door is opened. freezer seems to work well.
Going by the service manual it seems that everything is fine. The fan is supposed to run while the door is shut and the compressor is supposed to run 12 hours and then a 30 min defrost cycle comes on then the cycle starts over again. I am posting the service manual, parts and wiring diagram for you to view if you so choose. https://files.acrobat.com/a/preview/8a6d6ca4-04b6-4cfa-b435-3980042b3ad3
https://files.acrobat.com/a/preview/6d7f8a46-0daf-4e01-aa54-01f306301f31
https://files.acrobat.com/a/preview/12246a57-0a63-4d66-b3f3-7f7b67536da6
May 31, 2016 | Kenmore Freezers
Need manuel for a Kenmore frostless quick freezer model #253.9280410
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesthemobilian_748.jpgThe compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause defrost failure if bad.Not much to these babys.
Jan 07, 2011 | Kenmore Freezer 11.6 cu. ft. Upright...
True freezer model TS49f-RC. Evaporator fans will not run. Defrost timer will not stay in defrost when manually turned to defrost. Believe defrost termination switch is bad. ?
Nov 23, 2009 | Freezers
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Freezer dying?
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 14, 2009 | Kenmore Freezers
Running non stop!
Sadly these old freezers use way too much electricity. You will be better off junking this one and purchasing a good used or brand new one.
Apr 02, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
53 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
