Question about Apple iPod mini M9160LL/A MP3 Player
My ipod mini just stopped working cos i didn't recharge it for a while and now i have connected to the computer with the to recharge but the light won't turn on nothing is happening.
  • 177 Answers
Sometimes when the battery is very low, it takes some while charging before the ipod will have enough power to start up the screen etc. Be patient and see how it goes. If nothing still happens, it might have crashed, in which case press the center button and menu at the same time and hold them to reset.
Posted on Jul 19, 2010
I forgot my password and now my mini ipad is disable
it's now in DFU mode and must be plugged up to the computer and connected to iTunes.
Jul 18, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
How to recharge ematic esport clip using USB cable
You can charge it connected to your computer or buy an adapter that you can plug in the outlet for an mp3 player.
It comes with a USB to recharge on PC, you cannot recharge in iPod stand. I believe iPod has the market on this.
Sep 30, 2012 | Ematic Esport Clip 4gb Mp3 Video Player,...
Soon as USB is connected to computer - It freezes up and will not repond until the ipod is reset, using menu and center button. Freezes up also, when IPOD Power Adapter is connected for charging battery....
check your usb drivers are upto date
using the latest usb driver. its your pc that is at fault
not the ipod try connecting to another pc.
Ray
Oct 01, 2009 | Apple iPod touch
I have an ipod, 80 gb, that stopped working. Indications are: no screen lighting, no response. I have tried to recharge the battery with the ac charger and with the computer port. No luck. Since I paid...
Slide the hold switch on and off a couple of times.When hold is in off position press and hold menu and center buttons together until an apple logo appears on screen.connect to itunes and restore.
Sep 10, 2009 | Apple iPod - Digital player - HD 80 GB -...
My mini ipod freezing, showing charger sign i could not turn it to menu
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
Ipod problems
try your hardest
Aug 05, 2008 | Apple iPod nano
IPod 30 GB stopped working
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If there is no effect, then you have to contact apple, or your dealer for repairs, becouse a part is most likely damaged.
If you need more assistance let me know. Good luck.
Jan 13, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod was hang!
ya just hold the menu and center button till an apple image appears on screen!
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod Mini stopped working
Does it work while in a cradle or connected to the pc? If so, the battery is probably toast. I don't know if it is worth the investment to you to just get a new battery or a new iPod.
Nov 03, 2006 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
