Question about Samsung DV306LEW Electric Dryer
DOES NOT HEAT
THIS DRYER RUNS BUT IS NOT GETTING HOT. WAS WORKING FINE ON THE LOAD OF CLOTHES JUST BEFORE THIS ONE. I HAVE CHECKED ALL THE TROUBLE SHOOTING PROBLEMS OWNERS MANUAL TELL YOU TO AND CHECKED THE OUTLET FOR 220 OUTPUT.
  • 1,056 Answers
Dryers have thermal fuses that goes out. Unplug the dryer and check all the thermal fuse for continuity with an ohmmeter. A good thermal fuse would read very low reading in fractions of an ohm.
Posted on Jul 19, 2010
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
Having trouble with time even after being replaced it will not move have to watch so it will not over heat
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 09, 2011 | Dryers
My dryer model # ler331dso is getting hot on the top of the dryer but you have to run the dryer like three times to get the clothes dry? What is the problem? The lint filter and hoses are not clogged up....
The dryer might not be the problem at all. The electrical breaker might be on the way out:
The 120 motor's side is fine but the heat load side has taken a beating from the 5 thou watt 240 volt element.
Apr 30, 2011 | Frigidaire GLER642A Electric Dryer
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
Not drying as quickly, requires 2 cycles
look inside your lint trap to see if it is clogged. Also remove your vent hose to check for clogs there and at the outlet. make sure your hose isn't kinked.
Jul 20, 2009 | Whirlpool GEW9200L Electric Dryer
Gas dryer is not drying clothes
Go out to where the vent goes outdoors and feel if any air is blowing out of there with the dryer running. If you dont feel any air then probably your vent is blocked. You will need to clean it or fix the vent pipe if it is crushed.
May 12, 2009 | Dryers
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
I have an older 70 series dryer. I was working fine and then my last load of clothes didn't dry. The dryer did not get hot.
Based on your complaint; "I have an older 70 series dryer. I was working fine and then my last load of clothes didn't dry. The dryer did not get hot,"
Temperature Switch:
Make sure a positive heat selection has been made. Then check these:
This information is for an electric, generic model dryer only!
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 15, 2008 | Dryers
Samsung DV306LEW Electric Dryer Logo
233 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
