Dull vedio reception on rear projection tv
I have a phylips 9P5034C103 model rear projection tv which has sound and picture but picturte is very dull and redish.With red focusing knob,focus may change but with blue and green there is no change.Picture is snowy.What could be the problem
I have the same problem as Nadeem, but mine is green and blurry,,,,
Posted on Aug 08, 2008
How to clean guns on Magnavox Rear Projection TV Model 51MP392H
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
58'' TV IS SHOWING ALL RED
Dull Video...
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
May 21, 2010 | Philips 55PW9363 55" Rear Projection...
The picture is kind of dull. the cable guy suggested putting in a new bulb. how do we figure out exactly what part that is?
Your model doesnt have a lamp as the PT47WX53 is a rear projection with three CRts. Sounds like the mirror needs to be polished as that can make a picture appear dull and washed out
Sep 11, 2009 | Panasonic PT-47WX53 47" Rear Projection...
No picture
Hi, common problem, have a tech replace IC7412, gl, video-tek
Jul 03, 2009 | Philips 9P5034C 50" Rear Projection...
Need to change blue tube, just unscrew and replace with t.v. unplugged?
No - Your TV has tubes not lamps.
Why do you beleive you need to replace the tube. 99% of the time the problem with this model is just the fluid.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
May 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Dull
this is a common situation with the rear projection build. its a combination of the burn in effect and also, bad tuning. you can get a better picture by using the DVI option. rgb stream can give you a better picture as well. adjusting the sharpness can help sometimes.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rear projection the color is not as strong as once new
if its 2-3 years old model, then you need to service it and clean its rear mirror, front screen from inside tv and CRTs lenses.
you can do this by opening its back cover. if you post its model and brand, would be fine to help you in better way.
Sep 18, 2008 | Televison & Video
Phillips 9p5034c103
the stand by and start up voltages will need to be checked. you can get the service manual at the following link.
http://servicemanuals.vstore.ca/
Apr 21, 2008 | Philips 9P5034C 50" Rear Projection...
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
