Question about Bose Lifestyle 48 System
When playing a dvd the picture is black and white then shuts off?
4 Suggested Answers
SOURCE: DVD problem - now only plays in black and white
just checked by cables and that was it! Now have color back.
I have 321
Thanks a lot!
Dave
Posted on Nov 19, 2007
melnavz
  • 1226 Answers
SOURCE: bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Posted on Mar 31, 2008
  • 3 Answers
SOURCE: when playing a dvd it black and white no color
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the lifestyle system 5 years ago :-)
Hope that this helps everyone else!
Peter
Posted on May 28, 2010
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Toshiba 32DV502B
Hi my DVD is playing in black and white how do I fix this!!
May 05, 2013 | Televison & Video
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
Install s-video cable now dvd is black & white
you might have a bad cable just because you get a great picture but no color.i would exchange the cable where you bought it and try another one.
Dec 06, 2008 | Toshiba Cinevision DVR2000
No color picture on any DVD played
Make sure the scart lead in pushed in fully and none of the pins are bent!!
Mar 27, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD'S Play only in black and white
In UK this occures when an NTSC picture is played from a DVD player to a TV which cannot enitrely hand NTSC format. Possible this will happen in the reverse for USA.
Also my TV cannot handle SVHS signals and also displays them in black and white.
Try changing settings on the DVD Player to Composite or RGB.
Regards
Mar 10, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD picture is black and white
Sounds like you are either trying to play an NTSC (US or Asian) DVD on a PAL (European) TV.
Go into the DVD settings and look for picture, video or display options.
If the DVD is set to NTSC, then set to PAL.
Jan 06, 2008 | Philips DVD 622 DVD Player
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Bose Lifestyle 48 System Logo
139 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
