Question about Apple iPod MP3 Player
Ipod was restored and is left in plug into outlet screen
I recently restored my ipod clink (Old 20 GB Ipod with a Click Wheel)
After restore, it went into "plug into outlet mode", where I plugged it in and let it set for hours. And now it would leave that state. I've tried reset, and get the apple logo, then it goes back to that mode.
What can I do?
  • eovery May 01, 2008
    Da, already did this, and the problem was very much more than this. But you are right, the basic is all they have to offer you for a fix.
    Steve hit it on the head. The battery had to be replaced and this fixed it. I do not see any place in the manual about this diagnosis, so heed this as the solution in the future.
    When you hold down the menu and select for about 1 minute and it reset and comes up with a battery sign with a lighting bolt (meaning charge) I guess this is the diagnosis for replacing the battery.
  • Apple Master
  • 13,433 Answers
Start with the basic troubleshooting guide
try reset and restore again
http://www.apple.com/support/ipod/five_rs/classic/
Posted on May 01, 2008
  • Ekse May 01, 2008
    Hmm I supose so.
My computer won't recognize my nano ipod. When I first plugged it in a message appeared and said the install did not install completely and it may not work properly. Now the apple logo is on the ipod but...
I would recommend forcing the ipod into disc mode and then reconnecting to your computer to restore it using iTunes. Below is a step by step on my recommended solution just in case you need the information.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Jun 24, 2009 | Apple iPod MA446LL/A MP3 Player
Tip
How to reset a frozen ipod click wheel and touch
To reset any frozen iPod with a click wheel, you will first want to ensure that the hold button is not on or stuck by sliding it to the on position and then off again.
Next you will need to simultaneously press and hold both the menu and center buttons for at least six seconds but until the apple icon appears on the screen.
If this does not resolve the issue, the next best resolution is to plug the iPod into a wall charger and let it charge for several hours or until fully charged.
Then repeat the reset process.
To reset an iPod touch, you will need to press and hold the Sleep/Wake button and the Home button at the same time for at least six seconds or until the Apple icon appears.
As will the iPod click wheel models, if the first attempt does not work I would suggest charging the unit for several hours or until fully charged. After words, repeat the reset process.
If a reset does not resolve the issue, the next trouble shooting step would be to restore the iPod using the latest version of iTunes.
To restore an iPod touch, open iTunes on your computer and connect iPod touch to your computer with the provided USB cable. After a moment or two you will notice that in the left column under Devices, you will be able to see an iPod icon; click on your iPod touch, then click on Restore in the Summary tab. Follow any on screen instructions and do not remove the iPod until after it is completely restored.
To restore an iPod click wheel, open iTunes on your computer and connect iPod touch to your computer with the provided USB cable. After a moment or two you will notice that in the left column under Devices, you will see an iPod icon; click on your iPod. In the resulting page you will see a button that says restore. Click that and follow any and all on screen instruction ensuring that you do not disconnect your iPod until it is completely restored.
WARNING: If you do not have a back up of your data on the iPod you will have to re-gather it. I always recommend making a back up of your iPods content before an issue arises to ensure that there will be no lost data.
on Dec 29, 2009 | Audio Players & Recorders
My ipod wont work. when plug in both computer or wall dock, it just keeps blinking and resets constantly. nothing will work.
Try resetting it on purpose. If that does not resolve the issue, you will need to attempt to put the ipod into disc mode for restoring in itunes. Below I have posted step by steps on all three trouble shooting steps. If your issue is not resolved after working them please do let me know. :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. ----------------------------
-------------------------- PC and mac How to restore iPod (ARTICLE NUMBER HT1339)
May 08, 2009 | Apple iPod classic MP3 Player
I plugged my ipod 3rd generation 20 gb into my mac to delete some songs so I could add new ones...the screen came up in iTunes and it said it was disconnected improperly even though it was still hooked...
I would force the iPod into disc mode before attempting to connect the iPod to restore it. Below is a step by step on forcing an iPod into disc mode just in case you need the information :)
Apr 30, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Ipod 20gb click not recognized by windows
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time. :) Let me know if this does not resolve your connection issues
Apr 29, 2009 | Apple 20gb Ipod Mp3 Player With Click...
IPod froze up
Have you attempted to reset the iPod yet? If so and it failed you should attempt to force the ipod into disc mode and restore using iTunes. Below is a step by step on all three parts of the resolution. If for any reason your issue is not resolved after completing; please do let me know. :)
Learning how to reset or restart iPod following a freeze.
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. The screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center. --------------------------------------------------
Apr 27, 2009 | Apple 160 GB iPod Classic (Silver) +...
Screen black
Try resetting the ipod. If this fails you want to restore using itunes. I've posted a step by step on both trouble shooting steps as a just in case kinda thing... :)
Apr 26, 2009 | Apple iPod nano
When I went to turn it on it has only a white screen-nothing else there, won't sync, I've tried the 5 ways to restore and there is nothing there.
Have you attempted to reset the ipod? It sounds more like a hardware issue, but a reset may still help. Just in case you are unfamiliar with how to perform a reset i have included step by step instructions below.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
if you can get it powered on at all with the reset, I would suggest restoring it using itunes. As before i've included the instructions below just incase you are insure on how to do this step.
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If none of these steps resolve your issue, you will probably want to contact a repair service dealer of your choice. Or replace the unit all together. I hope this does resolve your issue though. Good luck :)
Apr 24, 2009 | Apple iPod classic 7th Generation
IPod nano is dead
Mar 11, 2009 | Apple iPod nano
Ipod Click wheel 20g is stuck plug into outlet mode after restore
I purchases the premiun service, but was not able to get the problem solved. The expert had me do the items in the manual, which I had already done. Any more suggestions?
Apr 21, 2008 | Macally iPocket MAIPOCKET
Apple iPod MP3 Player Logo
60 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
