Question about Maytag Washing Machines
Maytag washing machine dispenses hot water only wash and rinse
  • francis ciociola Jul 19, 2010
    It does it when the machine calls for cold water either in the wash cycle or the rinse cycle
    President:
  • 1,554 Answers
My understanding of the problem is that only hot water comes in when the machine calls for hot and cold water. This implies that the cold water valve is not working and you can find it out by interchanging the wiring of the valve solenoids. That is, connecting the wires of one valve solenoid to the other and vice-versa then restart the rinse function with the machine set to call for both cold and hot water.
The wires for the cold water valve solenoid are now connected to the known good hot water valve solenoid. Hot water should fill in when the machine calls for cold water which will confirm that the cold water valve is indeed not activating, especially when cold water does not fill in when the machine calls for hot water now that the solenoid wiring are interchanged.
Check the wiring connection of the cold water valve solenoid to the timer/control if hot water does not flow in when the machine calls for cold water but cold water flows in when the machine calls for hot water now that the solenoid wiring are interchanged. Make sure the wires are intact and the connections are snug fit. Replace the timer if the above troubleshooting procedures do not find any problem with the valves and the wiring.
Please indicate the exact model number of the machine for the specific procedure on how to access the water inlet valve assembly. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 19, 2010
    it is maytag legacy series and i have since found that this problem occurrs intermittently
  • Jahn27
    Jahn27 Jul 19, 2010
    The intermittent occurrence of the problem may signify a loose connection. Proceed with the troubleshooting advice outlined in the previous post. Disconnect power to the machine prior to servicing.
    Insert a plastic putty knife between the Top Cover and Front Panel as shown then press the locking clip to release the Top Cover. Do the same to the other on the other side of the machine. Support the lid with free hand and flip the Top Cover to the rear of the machine until it comes to rest on hinge stop.
    The water inlet valve assembly can now be accessed for inspection and troubleshooting.
Water is coming out of the detergent dispenser
This is probably due to excess detergent blocking the feed into the machine, try removing the tray and washing it in the sink. If this works I would rinse it out every month or so, this could be done in the machine by not putting detergent in the dispenser and putting the machine on a short wash cycle. Hope this helps.
Oct 26, 2015 | Maytag Neptune Washing Machines
Washer will not proceed to rinse cycle
Maytag leaks This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 14, 2013 | Maytag Neptune Washing Machines
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Adding bleach to front load washing machine
Put you bleach into the machine whist it is filling using the left part of the drawer.
Jul 03, 2017 | Maytag EPIC MFW9700S Front Load Washer
Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Apr 02, 2009 | Maytag Washing Machines
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Apr 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Only rinses hot water
for it to rinse in hot water, there has to be hot water going to it, try turning other valve 'off'it could be plumbed wrong way around rate me if i'am right. good luck Eire
Dec 05, 2007 | Maytag WD16 Top Load Stacked Washer /...
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
