Question about Brother MFC-640CW All-In-One InkJet Printer
Scanning Is there a way after scanning a document to save it as one document and not several documents (for multiple pages scanned) ?
  • 832 Answers
Do run the scan as a pdf
Posted on Apr 24, 2008
How do i make multiple pages scan as one document rather than each pages saving as seperate documents?
One of two things I can suggest:
1. make sure you are not scanning in JPEG or TIFF format as these are typically single page documents only. PDF is your best option for scanning.
2. Check settings, as some scanning software has an option that you can turn on or off depending on whether you want a single file with all pages or multiple files each containing a page.
Mar 09, 2015 | Canon PIXMA MP180 All-In-One InkJet...
How to scan multiple images into one pdf document
after scanning one page .. do not save the page but choose "add another image /page option " and scan accordingly.. and save the entire document after you are done with the scanning of all the pages.
Sep 30, 2010 | HP PhotoSmart C4280 Laser Printer
Want to scan several pages as one pdf document
Try OCR Terminal,which is an online OCR service that converts scanned images into searchable text. Register an account and you can convert 20 pages for free every month.
Have a try and hope it helps.
Mar 30, 2009 | HP Officejet J6410 All-in-one InkJet...
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Jan 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning several pages and saving as one document
Try this....
Scan your multiple pages to an image file, like .jpg, I know it's tedious, name them (optional) by page number, put them into an empty folder.
When you're done with all the scanning, open the folder, select all of them, open with: Preview.
Now, you should see one page, with a side bar containing all of the pages. (If they're not in order, you can drag and drop within the sidebar to reorder.) Select all of those (Or Command A)
Command P (Or Print)
In this window, you should see page one, and below that, make sure it says "Page 1 of XX"...this way you know you got 'em all, and it's your final opportunity to page through them all by clicking on the little arrows to make sure they're in the right order.
Click the PDF button
Save as PDF...
See if that helps
Jan 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Jul 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Single scan printers can be difficult in this manner.\
Consider using the OCR (optical character recognition) software that came with your scanner.
Basically the part of the software that asks you what you are scanning (picture, document, newspaper) and make sure to select document. This will enable the character recognition which will convert the scanned picture into a document that you can configure to go into Microsoft Word or Notepad or whatever. If you have multiple pages, it MIGHT give you the option to scan more than one page at a sitting. then again, it may not. In which case you might be kicking yourself for not purchasing the scanner with the auto feed attachment! Once you have made your scanned document in your word processor - READ THROUGH IT! may have converted characters incorrectly - like an "S" may be now a "$" it happens - and it will happen. When done, attach complete document to email and BOOM done.
Either this or use a fax machine :)
hope i helped!
Ryan
May 31, 2008 | HP PhotoSmart C4280 Laser Printer
Scanning
You'll need a scanner with an automatic document feeder (ADF).
Here's a Microsoft article on scanning documents, including scanning multiple documents info one file.
[Scan a document - Microsoft.com]
I hope this helps.
Greetings,
DarkNeogen.
Jan 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
229 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
