I have recently installed a EliteGroup Intel 945G-M3 (V. 1.0B) Motherboard and I have put in the ccables correctly, but for some reason not even my system fans are coming on! The power supply works correctly because I had it tested. So now the question is why is nothing working, not even the CPU fan? Anybody's help is greatly appreciated.
The way that I solved the problem was to unhook each and every connection to the motherboard except for the 4-pin and 24-pin power supply connections, the processor, the cpu fan and the power on switch connectors, once I have done that, then I plugged in the power supply and turned it on, in which that worked! After that, I would hook everything up to the motherboard one piece at a time, in which after each piece I would turn the power supply on again to see if that was the problem. Starting with the hard drive, the memory sticks and then the DVD drive, and found out that was the problem. The cable between the DVD drive and motherboard was the wrong cable for that motherboard. I will purchase a new cable and see if that works!
