Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Compact presario f700 laptop will not turn on. It
Compact presario f700 laptop will not turn on. It just went off. No power surge nothing. The cord still lights around it when plugged in. Any suggestions?
    Problem Solver:
  • 6 Answers
Was there any power outage in your area and was the laptop plugged in at that time, if so your Motherboard has been fried, your need a new Motherboard.
Posted on Aug 01, 2010
Compaq Presario F700 Won't Turn On
Assuming the unit is plugged in, this could be an issue with the power supply, or an issue where the cord connects to the laptop. If the power connector on the back of the laptop is secure / doesn't feel loose or damaged, you may want to simply get a replacement power supply from a local electronics store. Be sure to take the make and model information of the laptop and the power supply with you to the store.
Jun 08, 2013 | Compaq Presario Notebook
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Cant turn On my Compact presario f700
Assuming you have checked the the power strip or outlet by testing it with another electrical appliance to see if it is in operation, you can test
the power supply to the unit with a tester or oscilloscope. If it still does not work then check the cable that plugs directly into the unit and replace it if necessary. You can also open the unit to check if the cable is attached properly to the motherboard.
Aug 26, 2009 | HP Compaq Presario F500 F700 and G6000...
Compact Presario F700...Not Charging`
your battery may have memory OR it is on the battery recall list because it is defective try the manufacturer's site and see if the battery is being recalled
Aug 12, 2009 | HP Compaq Presario F730US Notebook
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
IT CAN BE FIXED.. HANDS ON IS THE BEST WAY . LETS GIVE THIS A SHOT. COMPAQ NOT GOING TO HELP YOU THEY WANT YOU TO BUY ANEW ONE IF IT WORK WHEN IT HAD VISTA , IT WILL WORK NOW, I AM SURE OF THAT. YOU MIGHT HAVE TO HAVE IT COMPLETELY TAKEN APART AND RESET IT , BUT THATS ANOTER STORY , FOR now remove the battery and remove the ram/ memory card, then remove the hard drive , a sigle screw should remove the hardrive memory as well then i want you to hold down the power button for about 3 minutes , then insert harddrive only press power, if you hear a beep good sign if th power button remains after the harddrive is installed, hold power button till computer turns off then install ram memory USE YOUR POWER CORD THREW OUT THIS PROCESS freddiemccly@yahoo.com your computer can be fixed i know its easy said then done ITS MINOR but a tech will tell you the total opposite
Jun 02, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq lap top presario f700 won't do any thing
try taking the hard drive and memory cards out then turning the computer back on without hard drive and memory cards for 1 minute then power it off (unplug it ) then put the memory cards in only then plug cord in turn unit on for 1-3 minutes then power down (unplug it) then add hard drive make sure there is no power going to the computer when adding the hard drive to the unit. at this point do let the unit set for 8 hours then try rebooting it should restore itself. if this don't work sorry there is a limit for what I $hare online.
May 12, 2009 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
459 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
