Question about Microwave Ovens
I change everything in the microwave and it heat and work normel but it doesnt compleat the cycle it turn off before the cycle
  • Microwave Ovens Master
  • 6,826 Answers
Sounds like a timer board is fried if it is a digital display model. If you already changed this part, then I don't know what else it would be.
If it is an older electrical mechanical timer model, then the interlock might be bad.
There might be an overheat switch inside the microwave that is tripping as a safety measure.
Posted on Jul 19, 2010
It doesnt heagt food
If everything else is working there are three common issues, magnetron,"heats food" high voltage diode, and the high voltage capacitor, "usually shorts" depending on age, probably more practical to replace microwave oven.
Mar 31, 2012 | Microwave Ovens
Microwave turns on but doesnt heat
The microwaves are produced by a MAGNETRON. Everything else can work, but if that does not, then there is no heat added to the food. Unfortunately it is the most expensive part of the microwave and has nothing you can really work on.
Hope this helps.
Apr 29, 2011 | Whirlpool GT4175SPS Stainless Steel 1200...
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Micro
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
srtat
Jun 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
MMV4205 doesnt heat up
If not a separate fuse, then the hi-voltage inverter or magnatron have likely failed. The first can be $130. The second $45.
Jan 30, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
