Question about Epson Stylus RX580 InkJet Photo Printer
Incorrect color prints on photos
At first it started printing the photos too yellow, everything was yellow like hair, etc., then i kept doing nozzle cleanings and head cleanings, etc., went through 2 cartridges, even 3 on some, and now everything is green. What is my problem?
    Scholar:
  • 161 Answers
Sounds like your printer is malfunctioning and has a problem. First I would delete this printer then reboot your computer and reinstall it and try again. If no success printer needs to go to shop or replace it.
Posted on May 04, 2008
I have a mac. how do i set up so i can start printing
Go to Canon website put in your printer model number an get the drivers an software for mac! hope this helps !
Sep 26, 2016 | Canon 3811B007AA model imagePROGRAF...
Why is this EPSON STYLUS C88+ "Dura Brite Ultra" printer printing the wrong colors?
You have a corrupt or incorrect printer driver. Completely remove all references to the current driver from the computer. Un installing is not enough as the registry references remain. Then install the driver(s) again.
Jul 22, 2014 | Epson Stylus C88 InkJet Photo Printer
My Epson R320 prints yellow over everything
One key diagnostic you need to perform is a nozzle check. This will tell you what has happened to the other ink colours as much as indicate if yellow is polluting other nozzles.
You can run a nozzle check from Printing Preferences > Maintenance.
Once it has printed you should (normally) see a sort of stepped grid pattern similar to this.
If you can scan or take a photo of the output and the post it as a follow up it'll then be possible to get a bit more of an idea of what could be happening.
Jun 30, 2013 | Epson Stylus R320 Digital Photo Inkjet...
My Canon MP980 Print/scan/photo Series printer is printing everything that is in color in yellow. I have cleaned the heads & nozzles. What is wrong?
Causes : Blocked by dry ink. Solution : Your Color i.e. Cyan & Magenta were malfunctioned/blocked. So try to clean them up tightly.. thanks
Sep 02, 2011 | Canon PIXMA MP980 All-In-One InkJet...
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
I just replaced the Yellow and the Photo Magenta cartridge in my Canon i900D printer as the computer advised. However, now my photos are coming out with green hair, lips and the other colors are not...
I would first try cleaning the print head, it is possible that print nozzles are clogged and simply not enough ink is able to make its way onto the media.
If the nozzle check page looks good I would try printing some full bleed color pages and see what it does, it is possible,but not likely, that there is either a air bubble in the ink system that could prevent ink flow. If this is true there should be a function for "priming the print head" and it should solve the problem.
Good luck.
Mar 18, 2010 | Canon Office Equipment & Supplies
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Epson 880 not printing in color
Found the answer. For some reason, my computer accepted a Mac driver. It called the printer Epson Stylus COLOR 880 (M). I went back to the original installation disk; thereafter, I had two printers, one without M, one with M, and deleted the M printer. All is working fine now.
Aug 09, 2008 | Epson Stylus 880 InkJet Color Printer
Dell Photo All in One Printer 964
Try printing a windows test page from the driver software, START-SETTINGS_PRINTERS-DELL964- properties,,etc. If the test page prints with color then I believe that your driver is set to print in greyscale. If you can't find that option in the driver you might try to re-install the driver from your original cd.
Aug 28, 2007 | Dell Photo 964 All-In-One InkJet Printer
Epson Stylus RX580 InkJet Photo Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
