Question about Ricoh Aficio 2035 Copier
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
    President:
  • 2,072 Answers
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Posted on Jul 19, 2010
    New Friend:
  • 31 Answers
Inside the Fuser Unit: Check for continuity in fuser lamp/s
Check for continuity in Thermal fuses
Check for high resistance in Thermistors (Mohm), NOT open!
Check connections/connectors. If all is fine, clear the Service call error, Yellow 1,0,7, orange buttons, the last one pressed 3 secs. enter and exit service mode, turn off and on the machine,job done!
If the code jumps up again, You have a melted fuse in Power supply.
But this is very rare. Good luck.
Posted on Jul 10, 2017
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Tenho problemas na minha fotocopiadora Ricoh 1027,aparece no ecram código SC548.qual saida para situação
SC548: Fusing unit set error
Symptom: The machine does not detect the fusing unit.
Possible Cause: • Poor connection of the fusing unit
• The fusing unit is not installed
Jan 09, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Functional problem sc548-00
you have fuser code you need to power cycle it. turn off the red switch then turn back 30 seconds later.you may need a tech to replace fuser parts
Dec 30, 2009 | Ricoh Aficio 450 Copier
Functional problem SC548-00
Try to reset the code, CLR modes key, then 1 then 0 then 7 and hold the red CLR/STOP key until your screen changes. press option 1 copy SP, then flip the red power switch on the left side of your machine. if you cant locate the switch unplug, but it is much better to use the switch
Dec 14, 2009 | Ricoh Aficio 450 Copier
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Error sc548 aficio 1022 ricoh
Poor connection of the fuser, and the code will need to be reset in service mode.
Jul 17, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 326c SC548
Fuser error. Problem needs to be repaired, and the code can only be reset in service mode by a technician
Apr 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio 2035 Copier Logo
4,973 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
