Question about Hitachi 42HDT55 42 in. Plasma Television
Mounting a Hitachi 42HDT55 plasma w a WM50
Just moved. Have an older Hitachi 42HDT55 plasma and the WM50 wall mount. It was professionally installed the last time, but now i have to do it myself. Can't find an online manual. Just wondering the secrets -- the wall on which I want to mount doesn't have studs in all the right places.
3 Suggested Answers
  • 319 Answers
SOURCE: plasma stand removal
take the screws out that are holding it in!
Posted on Apr 12, 2008
  • 47 Answers
SOURCE: wall mounting
http://www.tv-wall-brackets.co.uk/hitachi/32_inch/32LD8D20U/
hope this link gives u some information
All the best
Thank You
Posted on Aug 21, 2009
How do I replace the main board on Panasonic TC-55ST50 tv?
Replacing main board is a skilled work, as it might need a firmware update, and other adjustments. It will be best to contact any service technician. Contact the authorized service center for Panasonic, to buy a genuine main board.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 11, 2014 | Universal Heavy Duty Easy To Install...
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Need a base for Hitachi P501H401
You could visit the Hitachi consumer website or call them.
You could also Google the model number with "pedestal stand" "mounting base" etc as there are some generic bases sold--also might have a look (long shot) on EBAY for one.
May 26, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
Wall mounting
Hi, are you saying you want help with mounting your LCD TV onto the wall.
http://www.hometheaterblog.com/hometheater/2006/05/how-to-wall-mounting-a-lcd-or-plasma/
http://www.youtube.com/watch?v=lCNyc-KgCDY
If you need more help, please ask.
Regards - Anthony
Feb 10, 2010 | Proscan 37LC30S60 TV
How do I wall mount the 65" TV. There are no instructions in the manual provided with the TV
You can buy a universal wall mount the will fit on that 65" plasma that comes with all necesary hardware and instructions to mount the TV to the wall. Now that 65" tv is really heavy so it needs good anchors to support the weight of the display.
Jan 02, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Wall mounting
All the best
Thank You
Aug 21, 2009 | Hitachi Televison & Video
Hitachi 42HDT55 42 in. Plasma Television Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
