Question about Cuisinart Brew Central 12-cup Coffee Maker
My cusinart coffee maker is clogged so that the water won't come through to the basket. Tried vinegar. Are there any next steps?
ThaMp3Doctor
  • 8596 Answers
SOURCE: The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Posted on Mar 14, 2009
  • 19 Answers
SOURCE: slow water drip
First of all it depends on the hardness of the water. Vinegar doesn't really work in the heavy lime belt area of the midwest. It is better if you use lime away. It is an ecolab product that is great at lime removal. Use one cup per pot. Then rinse two pots worth if this is the kind of machine that uses the same water that is put in during each brew cycle. Some brewers have a reservoir. Bunnomatic is an example of that kind of brewer. If you use lime away in that kind of brewer you need to run about thirty pots to remove all the lime scale remover from the brewer. Slow brewing can also be caused by over softened water. I drove from Indy to Iowa after installing a brewer and then a day later the store put in a softener and over softened the water causing the coffee filter to clog up with sodium. Also check the sprayer disc or head where the water comes out. Over time coffee "paste" will build up around the outlet and if you don't wipe it clean or "smear" the coffee grounds around the outlet that will slow down the brewing cycle. I have thirty years as a brewer technician and it is usually one of the things I have covered, providing that the heat element isn't defective.
Posted on Aug 20, 2008
SOURCE: coffee maker parts
need a heating element replacement for model cm 500 coffee maker. How much does it cost? Mark
email to mmtazzy @yahoo.com
Posted on Sep 23, 2008
  • 1335 Answers
SOURCE: cuisinart coffee maker from costco, the grinds backed up twice.
It sounds like the release at the bottom of the basket was not open when you put the pot in to receive the coffee. You might check the release on the basket by takin the basket out, putting water in the basket and tripping (pushing up) on the botton on the bottom to see if the water flows through. It could be clogged.
You should clean the coffee maker about every 30 pots of coffee to keep scale from gathering in the heating tubes.
Posted on May 19, 2009
  • 8 Answers
SOURCE: algae in Braun coffee maker float tube
Use a mix of 50% laundry bleach and 50% water.
Half fill the tank and let it soak for several hours.
Rinse tank and refill with fresh water only.
NEVER RUN BLEACH THROUGH THE MACHINE.
Posted on Jun 24, 2009
Coffee maker won't work. says it needs to be de-scaled.
De-scaling is normally done through the use of vinegar. I prefer the white vinegar myself. This is simple. Instead of water, place a quart of vinegar in your water tank and no coffee grounds in the basket. Start the cycle. When it is all done, repeat with ordinary clear water, again no grounds in the basket. When this cycle is completed. if yours is a integrated tank, turn the coffee maker up side down to remove all liquid. Refill and enjoy your freshly de-scaled coffee maker.
Presto - de-scaled.
I trust you will find this solution adequate. Thank you for your interest in FixYa.com
Jul 11, 2011 | Vacuums
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    No water coming out makes noise and slite water and its not hot
    Use vinegar as water and soak over night. Use the same vinegar as water the next day as if brewing coffee. Then use fresh vinegar as if brewing coffee. Next use water several times until you don't smell the vinegar. Now try brewing a pot of coffee. good luck.
    May 12, 2010 | Keurig Elite B40 Coffee Maker
    Cuisinart coffee maker from costco, the grinds backed up twice.
    May 19, 2009 | Cuisinart DCC-1200 Coffee Maker
    Cusinart 12 cup grind and brew overflows with grinds and water
    Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
    1. Do not "pack" or otherwise overfill the cone/basket with grinds.
    2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
    3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
    4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
    5. Try a permanent filter rather than a paper filter or vice versa.
    6. Only use the correct permanent or paper filter (see manual).
    7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
    8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
    9. Ensure that the coffee machine is sitting level on the counter.
    Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
    How to clean the kitchenaid java express coffee maker
    The Coffee Maker can be descaled using
    a packaged descaling agent or vinegar.
    Always mix the descaling solution using
    cool water.
    • When using a descaling agent, follow
    the directions on the package for the
    recommended amounts of descaling
    agent and water to use.
    • When using vinegar, fill the carafe with
    a solution consisting of 1⁄2 vinegar and
    1⁄2 water.
    Descaling Steps:
    1. Before descaling, always remove the
    water filter (see “Installing the Ion-
    Exchange Water Filter” on page 7) and
    make sure the brew basket contains
    no coffee or coffee filters.
    2. Run the Coffee Maker through a
    complete brewing cycle using a full
    carafe of the descaling solution.
    3. If the cleaning needed indicator lights
    after the brewing cycle is complete,
    repeat Step 2 using fresh descaling
    solution. Keep repeating Step 2 until
    the cleaning needed indicator no
    longer lights after brewing.
    4. Rinse the Coffee Maker by running
    it through two brewing cycles using a
    full carafe of fresh, cool water
    each time.
    5. Wash the brew basket in hot, soapy
    water and rinse with hot water. This
    part can also be washed in the upper
    rack of the dishwasher.
    6. Reinstall or replace the water filter.
    Replace the filter every three months
    under normal usage, or more often
    with heavy use.
    Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
    Mr Coffee stopped brewing
    Sounds like there are a couple of problems -
    First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
    2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
    To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
    When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
    The coffee maker is now ready for it's next use.
    Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
    Cusinart DGB 550BK coffee maker not working properly
    Cuisinart Coffeemaker Decalcification Process
    Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
    -Tha Mp3 Doctor
    Jan 12, 2009 | Cuisinart Coffeemakers
    Open Questions:
    See all Cuisinart Brew Central 12-cup Coffee Maker Questions
    Cuisinart Brew Central 12-cup Coffee Maker Logo
    377 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    880runner
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
