Question about Insignia 600W Bridgeable Amplifier with 12" Subwoofer
Installing The Subwoofers to the amp... etc.
I recently purchased the insignia 600W Bridgeable amp with 2 12" subs and plan on installing them by myself. I hooked them up with 12 guage power wire and i believe 16 gauge speaker wire and i got the red light on the amp. I now believe i am under powering it and am planning on getting a bigger wattage amp kit with 8 gauge power wire. Is this the right thing to do??? i am really confused.
    Novelist:
  • 77 Answers
You should go with a 4 guage power wire kit. If your amp is going in and out
at high volume than that is your problem. 8 guage will work but, if you want
the proper current which is your power from your battery, going to your amp
than I would recomend the 4 guage amp install kit or just the main power
wire coming from your battery. If you would like contact me and I will send you
to a very good sight with all the info you will ever need for car amplifire installation.
Posted on Jan 05, 2009
Yes, the 8 gauge wire kit is the normal wire kit for amps over 300- up. Because, 12 wire gauge isn't that strong for current required by the amp to work efficiently.
Posted on Jul 15, 2008
Amp wont turn on just thr red thermal light
First ceck yor ground. itshoul be grounded directly to the frame andto clean bare metal. sedonc check your wires to make sure nothing is chaffed and grounded out. after that you can check yur subs to make sure the ohm load is safe for your amp..let me know if theres anyting else to help out!
Jul 25, 2010 | Insignia 600W Bridgeable Amplifier with...
Theres a red light on the amp instead of the green light
First ceck yor ground. it should be grounded directly to the frame andto clean bare metal. sedonc check your wires to make sure nothing is chaffed and grounded out. after that you can check yur subs to make sure the ohm load is safe for your amp..let me know if theres anyting else to help out!
Jul 02, 2010 | Insignia 600W Bridgeable Amplifier with...
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
So everything is on and i can hear the amp running but the amp light isnt' green or red, its jus clear and no sound, what seem to be the problem?
Apr 29, 2010 | Insignia 600W Bridgeable Amplifier with...
Have alpine 10 r subs can insignia 500w amp hook up and how to wire subs
if the speakers are 250 watts each then yes if speakers are less you will blow them cuz of to much power if they are more then you most likely won't be able to push them
Sep 24, 2009 | Insignia 600W Bridgeable Amplifier with...
Need to know how to hook up a subwoofer to an amp
thats easy if you have posted the specs of amp and sub.are subs 1 2 4 ohm? what is the power rating of both amp and subs in 1 2 4 ohms.u need to post some info to get help.:]
Aug 27, 2009 | Sony Class AB 600W Bridgeable 4-Channel...
My red light on my amp is on and wont go out
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
Apr 03, 2009 | Insignia 600W Bridgeable Amplifier with...
Amp getting hot and shutting off
no mine do that and its pretty much normal
Jun 06, 2008 | Insignia 600W Bridgeable Amplifier with...
Open Questions:
Insignia 600W Bridgeable Amplifier with 12" Subwoofer Logo
373 people viewed this question
Top Insignia Car Audio & Video Experts
Mark Skinner
Frank Mangiapane
Level 1 Expert
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
