Question about Whirlpool Dryers
Removing lower front panel for electric gew9868kl1 whirlpool drye
Trying to find the thermal fuse since sensor light remains on and dryer does not operate. Unable to get the front panel off though>
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Whirlpool Dryer Help
Hi theres 2 things that can cause this #1 a dirty vent to the outside. #2 a dirty lint filer , Take the lint filter out & run hot water through it. If water wont flow through the screen, Its gummed up by Bounce sheet residue, Clean the filter . It should be ok
Posted on Jan 21, 2009
danromarris
  • 101 Answers
SOURCE: My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
Posted on Jan 22, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
vostendorp
  • 347 Answers
SOURCE: Whirlpool Duet dryer runs for
E1 error code is a problem with the thermister sensor is is located behind the lower front panel..you do NOT have a thermal fuse concern because the unit will not run at all if its blown.MAKE SURE TO UNPLUG UNIT BEFORE REMOVING THE FRONT PANEL.. ps the thermistor is mounted on the blower housing and is kind of oval shaped ,the thermal fuse is about and inch long skinney and has 2 blue wires going to it hope thus helps Good luck
Posted on Aug 22, 2010
Testimonial: "Thank you so much for your advice. I'm going to purchase the thermal fuse as well, for the extra few bucks its well worth it. I'll keep you all posted"
Will not ignite, not even a click. Sounds like thermal fuse; how do you remove bottom panel and check it?
To remove that panel use a putty knife placed in the seam about a inch or two in from the corners
between the main front panel and that lower panel and push in the clip that hold lower to upper panel once both clips released panel can be tilted down and removed
To check the Thermal fuse UNPLUG DRYER use multimeter set to lowest ohms setting,remove the wires off of thermal fuse and place meter leads on the 2 terminals..if thermal fuse is bad the meter display will be OL or if have meter with needle the needle will not swing
Their are 2 types of thermal fuses the pictures show what the 2 styles look like it will be one of those 2 types
Aug 23, 2011 | Whirlpool GGQ9800L Gas Dryer
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Whirlpool Duet dryer runs for 1 min. and then shuts off with e1 error, I did some research and found out their is a thermal fuse located behind the lower panel. Also something about a the heater could be...
    Aug 22, 2010 | Whirlpool GEW9200L Electric Dryer
    Removing a part form a Whirlpool Electric Dryer
    The thermal fuse is located on the outside of the blower housing. To get access to the thermal fuse you will need to remove the back panel of your Whirlpool dryer.
    How do you check it:
    Before you do any repairs on your dryer, you will need to disconnect the dryer from the wall outlet.
    After removing the back panel, remove one wire from the Whirlpool dryer thermal fuse and take a reading between the two terminal on the thermal fuse.
    The reading should be 0 ohms, if the reading is infinity, the thermal fuse is bad and it must be replace. When you find a bad thermal fuse, you will need to replace the operating thermostat too.
    The operating thermostat opens at 155 degrees and the thermal fuse blows at 196.
    These means that operating thermostat did not open at 155 and that is why the thermal fuse failed.
    Jul 12, 2010 | Whirlpool Dryers
    This morning my dryer stopped working when I put in a new load. It simply is not heating and the drum is not turning
    YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH RAPIDLY. SECOND AND MOST COMMON THE WHITE THERMAL FUSE WITH BLUE WIRES TO IT HAS BROKE. LOCATED BEHIND THE LOWER FRONT PANEL. UNPLUG DRYER, REMOVE LINT FILTER, REMOVE LOWER PANEL, REMOVE THE LOWER DUCT ASSY. THIS IS THE PIECE THAT THE LINT FILTER GOES INTO. BEHIND THE DUCT IS THE WHITE THERMAL FUSE.
    Apr 25, 2010 | Whirlpool GEW9250 Electric Dryer
    Drum very difficult to turn manually. not spinning with ac on
    If your trying to turn the drum from the inside, or by opening the top and trying to turn, there will be some resistance.
    What are the symptoms of your problem? Does the drum not turn when the dryer is turned on (with or without clothes)?
    If so -
    1) the idler roller could be bad
    2) The motor is bad
    The motor is internally thermally protected and no thermal fuse is used outside of the motor. Only place a thermal fuse is used is to prevent overheating.
    Provide more information to you problem.
    The lower front panel is not removed to service this unit. All service is done from the top or rear.
    Jan 15, 2009 | Kenmore 659 Electric Dryer
    Lighting the pilot
    there is no flame type pilot. when you turn on the dryer remove small cover on lower left front panel to view if you see a orange glow, which means your ignitor is getting power listen for 1ckick sound and then a second after the ing glows. there a few things that could be bad ignitor. soleinods on the gas valve or a bad thermal fuse
    Dec 19, 2008 | AEG T57800 Electric Dryer
    Dryer clicks when start button pushed but does not start.
    A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
    Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
    Whirlpool Dryer Model GEW9200LW0-Shutting off
    Guest. Your thermistor has opened, it's very easy job and inexpensive. You will have to remove the lower panel. Right behind the vent housing will be the themistor and thermal fuse. The thermistor will be the black one on the right of the thermal fuse. Kill the power, Two quarter inch screws holding it on, two wires going to it. Here's your tech sheet if the link works, http://www.servicematters.com/docs/wiring/wiring_main.htm Catriver.
    Jan 13, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryers Logo
    49 people viewed this question
    Top Whirlpool Dryers Experts
    Sal De
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
