Question about GE Kitchen Ranges
Bad timer on GE gas stove
I have a GE gas range with a bad timer. The timer is part # AP2020548. Apparently, this timer is no longer available. 2 questions:
1. Is there a work around.
2. Is there any place I can send the timer to get it fixed.
  • 41 Answers
SOURCE: GE TrueTemp Gas Stove
Not sure that I can help but will give it a go. Often the igniter plastic covering comes off the wiring from the heat of the oven and the igniter arcs on a metal surface on the oven. I had this problem with a gas oven I had. Check along the igniter wiring to see if it is arcing. Best way to find it is to firstly locate the wiring then ignite the oven WITHOUT THE GAS ON. If it is arcing you should be able to see a little flash. Check to make sure it is flashing at the right spot first near the pilot. Easiest way to rectify this problem is to wind electrical tape around the igniter providing you can get to the wire. If you have to pull out the igniter you can buy a plastic product called Heatshrink from places like Tandy or Electrical Hardware Stores. Just put some Heatshrink or Electricians Tape around it and it should solve the problem. Only other thing it could be is the igniter needs replacing. Hope this helps.
Regards
Bryan
Posted on Feb 28, 2008
IrishDruid
  • 2712 Answers
SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
mgprice
  • 744 Answers
SOURCE: GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Posted on Oct 01, 2009
The control panel is flashing F1 oon my stove. A technician told me that parts were no longer available. I think the stove is about 15 years old and I don't have the model number with me at this time....
The code is: 'failed thermistor control' and the bad part is the 'electronic range control'. Look inside the oven door opening edge for a model number--usually an aluminum plate glued to the surface. Once you find the model number, get on the internet and search (GE mod#, part). If doing your own repair, be sure to remove power by pulling the plug or switching off the appropriate breakers.
Feb 04, 2010 | General Electric Stove/Oven/Range Chrome...
Ge gas stove top keeps clicking
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Sep 22, 2009 | GE Kitchen Ranges
GE gas stove switch igniting though stove is off!
You have a bad ignitor switch. One or more of them (4) is stuck.
You need a volt/ohn meter to check the switches, one attached to each surface burner to find out which is bad.
Feb 19, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
MAYTAG GAS RANGE MODEL # MGR5765QDW
sounds like a bad bake ignitor, common issue with all gas stoves.
Nov 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGSP32GEV3BB slide in range - regulator went bad #WB19K5020
"GE makes garbage" that's what a lot of independent servicers says about brands they can't become authorized to work on because GE for instance has factory service. What makes the repairman think the regulator is bad? It is highly unlikely to be the case.
May 12, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
