Question about Poulan Pe550 Gas Edger
Toro Gas edger.
Edger starts but dies when I give it the gas
  • 4 Answers
The srew on the carburator that adjust the air fuel mixture needs to be turned out 1/2 turn or the choke is on.
Posted on Jul 21, 2010
Will start and idle,but give it gas and it dies.
Hi Tammy:
Make sure the air filter is clean.
Check the muffler. Sometimes they get clogged with carbon and the unit will idle but dies when you try to increase revs.
May 04, 2015 | Craftsman Gas Mini - Tiller/Edger
Gas powered weed eater/edger has no power (starts fine but attachements won't spin with any velocity
You need to check compression with a reliable 2 cycle compression gauge, not an automotive one. Probably should also be pressure and vacuum checked too.
Oct 05, 2014 | Toro Garden
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
Master cut edger 2.0 manuals wont start
Not positive but it sounds like it ran out of gas. Maybee a leak in one of the hoses? Or a piece of trash worked its way into the needlevalve or internal screen
May 11, 2010 | Garden
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Engine starts and dies immediately what could be wrong?
The carburator may be dirty or the fuel filter might be clogged. I would take it off and clean it with some carb cleaner and see if that fixes your problem. It might be benificial to run fuel stabilizer after you clean it.
Apr 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Edger starts but when I give it gas it stalls.
when i give it gas it stall
Jul 11, 2009 | Garden
I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Jun 13, 2009 | Craftsman Gas Mini - Tiller/Edger
Poulan pe550 edger problem
Did you adjust the carburetur screws?
Sep 12, 2008 | Poulan Pe550 Gas Edger
Poulan Pe550 Gas Edger Logo
156 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
