Question about Frigidaire FAC124 wall/Window Air Conditioner
My unit keeps freezing. How do I stop it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
First, make sure you have it set at a mid temp. Eventhough the thermostat says it will make ice cubes, it isn't supposed to. The unit should cycle on and off with a room temperature of 70 - 72 degrees.
Secont, make sure that the filter and the insode and outside coild are clean. If they are dirty, wash the filter and gently bruch the coild, being careful not to flaten teh aluminum fins.
If you are handy, take the unit outside, remove the cabbinet (and with it UNPLUGGED), spray it down with a garden hose, running water through both coils. Let it dry fro a few hours, put the cover back on and put it back in the window.
If you still get icing, you probably have a low charge. With the cost of labor, and the price of window units, you'ld be better off replacing it than fixing it, unless you have a local air conditioning school that will do it for cost of materials.
Posted on Jul 19, 2010
I have a spt wa-2211s AC window unit when i turn it off the compressor keeps running have to unplug it to make it stop running
So the compressor keeps running , fan shuts off and coil starts to freeze??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 03, 2017 | Heating & Cooling
I have to push on my freezer door to keep the blower running
there is a loose connection at the rear of the freezer near or around the compressor unit , i strongly advise you to get a professional to look it.
Regards
Dec 16, 2012 | Haier Freezer HUF168PA 16.8 Cu. Ft....
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
My window ac unit keeps cycling off, before it gets to the assigned temperature. Help
What may be at issue is evaporator icing. Some units cycle the compressor, others control the refrigerant to keep the evaporator temp just above freezing. If allowed to continue the evaporator would freeze over and air flow would stop....
Check and see if that is the case...
Jul 20, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
Had a loud noise coming from the freezer, water all over inside.
Hi, what sounds to me what happened, is the evaporator fan motor prop (blade) has hit a patch of ice that had built up and temporally caused the unit to stop and warm up. I have seen this happen on commercial units to where after the unit has went through its defrost cycle as you will have on this system, not all of the ice was melted away and the fans stopped due to ice build up. When the defrost cycle happened, this caused the water at the top back and after the fan began to run again all is freezing and back to normal. When a evaporator fan stops during the regular cooling cycle, the freezer section will start to over freeze very badly due to no air flow across this coil. I would keep an eye on it as you may be loosing this motor. It is called the evaporator fan motor, 120 volts/a/c, 60hz. small sealed, single phase. R.P.M.s and H. P. should be noted on a data plate on the unit maybe inside, you will need to look. In any case, keep a close eye on it for now if it is working correctly. You may not have this problem again. If it does happen you can contact me and we can go into more detail to solve the problem.
Sincerely,
Shastalaker7
Mar 10, 2010 | Samsung RS2630SH Side by Side Refrigerator
Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
Whirlpool S20BRSB21: The fridge side keeps freezing
call a repair service , the air damper control needs fixed, if you have lowered the control value all you can
Mar 04, 2018 | Whirlpool Refrigerators
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Frigidaire FAC124 wall/Window Air Conditioner Logo
135 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
