Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
When i turn on the garbage disposal switch the noise will come on but the blades will not turn. After a while the noise stops and i have to unglug the system and hit the red reset button. When the reset button clicks in the noise will continue for a short while and then the button pops back out and the noise stops again.
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
b
Posted on Sep 29, 2010
Garbage disposal makes loud noise, nothing stuck, blades turn freely
Bearings in the motor are worn enough to allow the grinder plate to rub against the side of the chamber.
Apr 10, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal hums, but doesn't work. blades turn freely, as well asthe motor with a wrench- with no pressure?
Copy following link for disposal troubleshoot, and replacement tips:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Sounds like disposal motor has overheated and shorted.
Fortunately today's disposals are fully contained, and did not cause fire.
Replace disposal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 16, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Motor seized
If cutter blade is not rotating freely, then use allen wrench in slot on bottom of disposal or use wood boom-stick handle in sink upening to wedge cutter blade loose.
If blade rotates freely and motor stopped working, then disposal is broken.
I wrote ez disposal replacement tips from years when I worked apartment maintenance.
Apr 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
Feb 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Blades are stuck! Help!!
have been a pluming mechcanic (yes no license) for 25 yr's and have never ben able to replace blade's on any disposal , from any manufact. do believe some blade's are stationary.
Apr 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal blade locked up after finding bone piece
You need to purchase a garbage disposal wrench. It has a Tee at the top and extends down to a pivot with a large forked head. Drop this down and turn the blades until they start to move. Remove the wrench, run hot water and turn on your disposal. Both blades should now be free. There also might be a red reset button on the bottom.
Jul 04, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
In sink erator( 5 horsepower) doesnot function
On the bottom of the disposal is a place for an allen wrench. Take and turn the unit with the allen wrench to break it loose. It sounds as if has something sticking the blades.
Jun 03, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Metal nail fell into the garbage disposal.
Just above the motor par of your incinerator there should be 3 or 4 small bolts or srews that holds the main motor onto the waste chute TURN OFF THE POWER. Remove these bolts to seperate the motor and you should be able to remove the nail. Please, please make sure the power is off.
May 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
258 people viewed this question
Top Ace Hardware Electrical Supplies Experts
Craig Butler
Craig Butler
Mike
Steve Allison
Steve Allison
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
