Question about Garden
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
  • 2,272 Answers
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 19, 2010
  • 6,826 Answers
OK, a method I use in routing belts follows:
Look at each pulley and see if it is a v-belt pulley, or a pulley with a flat part on it (not a V).
Route the belt over and under until the belt you bought fits the very last 'adjustable' angle pulley (say for instance the clutch pulley pivots and loosens the belt tension).
The new drive belt (for moving the mower) vs. the belt for the mower deck can be routed in a similar way, once the shields are removed on the mower deck.
It's really that simple. Good luck to you on this repair.
  • Duane Wong
    Duane Wong Jul 19, 2010
    If you want to remove a belt that is still intact then note the routing on a diagram you draw, and then disengage the tension with the foot pedal and undo the belt by pushing side to side on the belt at the pulley.
My 100 cc quad doesn't idle rite and the bike revs real high when riding n sometimes stuck at real low could it be carborator or transmission
Clean air filter an stuff intake, and check for leaks around intake boots ( cracks,dry rot , loose or fallen off hoses. Tranny most likely fine. Check belt drive could need new belt also
Jan 07, 2017 | ATVs
I have an oldstock new in the box Fisher PH-W405 and I need to replace the tape machine belts that dry rotted over the years. I have a service manual for it, but it don't tell me how.
  • Disassemble unit to expose belts
  • Remove old belts
  • Install replacement belts
You may have a problem finding exact replacement belts for an old machine
May 27, 2016 | Audio Players & Recorders
Change belt on washing machine
Go to www.repairclinic.com and enter the model number of your machine. You will be presented with a list of common replacement parts and may be able to view a video showing the procedure.
Feb 19, 2015 | Whirlpool Washing Machines
Replace Water pump
Its on the passenger side, lean over fender and look lower bottom of engine. I replaced mine BUT all I really needed was the plastic elbows, dry rotted. $5.00 opps.
Apr 12, 2014 | 2002 Chevrolet Impala
Vertical drive
If it's where i think it is you have to disconnect the axel rod off of one side and put the belt around the shaft from there.
Feb 07, 2018 | Garden
Belt splitting
Belt is either worn out, rotted or a pully is going bad. Remove the belt check the pullys don't wobble that they spin straight and are not loose and replace as needed and install new belt.
Jul 25, 2011 | Plymouth Voyager Cars & Trucks
My serpentine belt flew off my 1999 Audi A6 Quattro. I want to do this job myself and was wondering if anyone has a belt diagram and also a list of what tools I will need? I am hoping I do not need to...
you will need to determine WHY it came off in the first place. belts just dont fly off for no reason. you may be better to find a shop that does euro work and is familiar with audi.
Dec 21, 2010 | 1999 Audi A6
Need a new water pump but should i replace the timeing belt also,or do I really need to unless it's worn out
it depends if you =know= how old the timing belt is. if you dont or it is past about 80,000 miles i would replace it also to avoid extensive engine damage if it brakes. you almost have to remove it to look at it closely for signs of dry rot and cracking,this still is no quarantee as to its life span.
Feb 17, 2010 | 1999 Honda Passport
Sqeeking noise.
sounds like u need a new belt may be dry rotted or just worn but also look at your belt pullies
Jul 12, 2009 | 2000 Nissan Pathfinder
Garden Logo
310 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
