Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Dishwasher stops working after a minute. It fills with hot water then shuts off. It is a Matag quiet series 100
    Problem Solver:
  • 5 Answers
Could be a bad thermistor
Posted on Jul 21, 2010
My dishwasher 100 ser-it fills and it starts to run no water coming throw jets
Posted on Sep 21, 2011
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
My maytag quiet series 100 is stopping after only 3 or 5 minutes into the cycle. Any idea what this could be?
Could be the door switch is loose, check to make sure its secure and not free to move around.
Jan 26, 2015 | Maytag Dishwashers
Frigidaire Professional Series dishwasher started to have hot water suddenly fill up dishwasher and the pour out onto my kitchen floor. The dishwasher was not on. I had to press cancel button to get water...
I think your hot water inlet valve has failed open. It is electrically operated, and can stick in that position.
If not that, it is possible that the water level sensor signal has failed, but that should only be apparent when the washer is on.
It requires a service call.
Feb 04, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag quiet series 300. fills up, runs, then shuts off early with water in the bottom. sometimes it shut off a minute after starting it.
You could have a problem with the door locking mechanism or the motor control board. You should have a tech check that out because if you purchase the parts and they dont fix the problem youll probably be out a small chunk of change.
Sep 16, 2009 | Maytag Dishwashers
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
My Maytag dishwasher Quiet series 100 gets no water
I would cheak your float switch witch is located on the bottom of inner dishwasher move it up and down may be stuck.then try.If that will not work you may have a bad micro door switch.Good luck:)
Apr 08, 2009 | Maytag MDB5100A Dishwasher
Whirlpool dishwasher will not fill with water
turn the valves to the left if there the screw in type or parraell if the quick open type the first thing a dishwasher does when you start it is drain for a few minutes then stops then fills with hot water run the water as hot at the sink as you can before starting the washer there is a float in the tub that can shut the water valve off if its not seated on the safety switch after the drain at the start of cycles stops then you should hear the water valve open and start the fill let me know and we will go from there
Mar 27, 2008 | Frigidaire 24 in. FDB126RB Built-in...
MayTag Dishwasher Quiet Series 300
If it is not filling enough, you may need a new water valve. It may be plugged.
Nov 19, 2007 | Dishwashers
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
933 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
