Question about John Deere Gator and riding mower deluxe seat cover
I have a john deere 325 with a kawasaki 18 hp v twin and the
Engine bogs down, then runs fine, and bogs down again. The carb has been checked and its ok, the fuel filter has been changed, I checked the plugs, one of them was clean and the other was black. When I removed the plug that was black, it was alot hotter than the plug that was clean.
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
Kawasaki 17 hp stalls when hot
you need valve job done and new valves put in and i said new valves do not use old valves again 150.00 per cylinder
Sep 07, 2014 | John Deere Garden
Why does it idle up & down constantly
which v-twin ???
Kawasaki or Briggs or Kohler
but I'd suspect a dirty carb just by your question
Aug 30, 2014 | John Deere Garden
John deere x 300 carb needs adjustment
If you want to solve your problem, click on the link I attach.
JOHN DEERE X300 SERVICE REPAIR MANUAL
Apr 20, 2017 | John Deere Garden
Engine seems to run fine but when mower is engaged it loses power. It is a john deere 325.
Check to see if the mowing deck spins free or somewhat free with the engine off, It might be wrapped up with twine or something stopping from spinning, this will bog down the engine. Hope this helps.
May 29, 2011 | John Deere Garden
I have a LX277 tractor with a Kawasaki 17hp twin. The problem I'm having is the engine bogs down under load. Seems to run fine otherwise. I've replaced the fuel filter, spark plugs, sharpened the blades...
Run some combustion chamber cleaner directly into the carb. It is much better at cleaning clogged jets and orifices than commercial carb. cleaner. Pour in slowly at high idle while it is running. It will smoke like crazy. Bog it right out with the pour then let the machine sit for an hour then run the engine fast to complete the clean. Hope this helps!
Rob
Sep 22, 2009 | Garden
John Deere Gator and riding mower deluxe seat cover Logo
143 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
