Question about Pentair 2.0 Hp Whisperflo Pump
Pool pump problem
I am working on a friends pool. He has a Pentair Whisper Flo 2 HP pump. WFE-8. Whom ever install this slid the PVC pipe directly into the pump without a threaded fitting and it leaks. My question is 1) does this pump have a threaded fitting like every other I have seen. 2) If so, what is the best way to get this out, clean the threads (I figure they tried to glue it in) and get it working correctly again.
Thank you
Peter Wood
  • 2 more comments
  • Peter Wood Jul 23, 2010
    Let me re-phrase the question.
    Since the PVC pipe seems to be glued in place instead of threaded in, is there a way to remove this pipe and chase the threads without damaging the housing. I don't want to trash the pump.
  • brett_wil622
    brett_wil622 Jul 19, 2012
    Pete,
  • brett_wil622
    Pete,
  • brett_wil622
    Heat the PVC with a butane flame and cut a section out then attch a pair of needle nose pliers to the cut end and rool the PVS fitting up on the pliers. try not heat the tread ininlet to extreme.
  • 360 Answers
It's quite difficult for you to remove the glued part, you have to be extra careful in doing this, first of all you use a saw to cut of part of the pipe, then you can now gradually use a screw driver to peal off the remaining glued part to the machine. It's quite tedious and you have to be careful or else you damage the machine. If you think you can't do it, get a plumber around to do it..
Posted on Jul 23, 2010
    Is there anything out there I can use to chase the threads if they are damaged or filled with glue?
    Thanks
  • Quadri Olatunbosun
    Quadri Olatunbosun Jul 23, 2010
    Hi, i think there are things you can use to chase the threads if they are damaged or filled with glue but i have not come across one yet but a visit to any shop into plumbering parts will do no harm.They will be in the best position to tell you that.
    Thanks
  • 532 Answers
This pump have a threaded fitting like every other.
Compatible with all cleaning systems, various filters and jet action.Cam & Ramp lid makes cleaning and inspection simple and quick
For additional information on Pentair WhisperFlo pumps contact the manufacturer at: ...
www.aquapoolstore.com/pumps/Pentair-WhisperFlo-Pool-Pump.htm -
Thanks for contacting Fixya.
Posted on Jul 19, 2010
  • Rahman Rufai Jul 23, 2010
    If the pipe is glue to the pvc it means you have to cut the pipe neatly clean it properly and use a tangy gum to glue the pipe to the pvc. a tangy is used to to glue pipe together.
    Thanks.
Pool plumbing diagram
You may experience a little pressure loss, but if the catridge fliter housing has a 1 1/2 input you should be fine.
Jul 17, 2014 | Pentair Clean and Clear Cartridge Filter...
Have a 2 hp 2 speed Pentair whisperflow pool pump, it seems to only operate in low speed.. is about 5 years old..checked for obstruction at impeller but seems fine..any suggestions much appreciated..
check for power on high with a meter, or bring it to your local pool pump motor repair guy with free testing. TAKE NOTE on where the wires are hooked up !! they must go back the way they came off !!!
Sep 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pentair superflo electrical wiring
if 220 volts 2 blues 1 to L1 one to L2 green to ground or case
Feb 08, 2012 | Pentair Super Flo 1 Hp Pool Pump 340038
Pump needs to be reprogramed
Whisper flo pumps do not have a computer to program. If it is an INTELLIFLO you would need to program. The programming manual can be found at PENTAIRPOOL.com
Sep 08, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Three pvc pipes coming into an max i flo pool pump should all three valves be open to run the pump?
Here is a link for the users manual for these pool pumps. You should be able to not only see a diagram, but also read all about which valves should be open and which closed.
http://www.backyardcitypools.com/images/hayward/power-flo-manual.pdf
Jun 19, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Whisper Flo model WFE 6 (1 1/2 HP) appears not to turn thus not pumping water through system; only clicks on/off when pressing fitler motor button on panel. Other spa equipment consists of: Pentair...
Possible bad motor. You would need to test voltage at the motor connections with a multi meter. If the voltage is correct, then the motor or start capacitor is bad. If the proper voltage is not correct, then you would need to look upline in the electrical system to find the problem
Oct 25, 2009 | Pool & Spa
Pentair 2.0 Hp Whisperflo Pump Logo
48 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
