Question about Sport & Outdoor - Others
Huffy Pro Shot Portable Basketball Goal Instructions needed
We received a Huffy Pro Shot Portable Basketball Goal as a gift, but without the instructions of how to put it together. Where can we find those so we can put it together?
SOURCE: do not have the instructions for assembling a
http://www.lifetime.com/customer-care/instructions.aspx
Posted on May 11, 2009
  • 4 Answers
SOURCE: need instructions for backboard assembly
http://huffysports.russellcorp.com/Instructions.htm
Here is the link to download the manual
Posted on May 14, 2009
walesarumi
  • 6993 Answers
SOURCE: I have an old huffy
Follow the below assemble instruction as requested for your huffy sports basketball hoop;
Insert the mounting screws through the mounting holes of the backboard, then lay the backboard face down. Lay the mounting brackets on top of the backboard so the mounting screws of the backboard go through the mounting holes of the brackets. Tighten the screws with a wrench.
Insert the adjustment hardware between the brackets and insert the screws connecting to the brackets to the adjustment hardware, then add a nut to the screw and tighten with a wrench. These screws will be inserted horizontally through the brackets into the adjustment hardware. The adjustment hardware allows you to adjust the height of your basketball hoop.
Line up the holes of the rim to the holes of the backboard and install the rim screws through the rim into the backboard and secure them with a nut. Tighten the nut with a wrench. Thread the nut through the wire holes of the rim.
Assemble the pole. Dig a hole with a shovel where you want to install the basketball hoop. For the exact size of the hole, you will need to consult the directions on your Huffy basketball hoop. To achieve the regulation height of 10 feet, this step strongly depends on the size of the particular basketball pole and a specific measuring depth. Measure the hole with a tape measure for accuracy. Mix a bag of cement in a wheelbarrow with water. Consult the directions on the cement bag for exact mixing instructions.
Place the pole in the hole and shovel in the cement. Allow the cement to dry.
Use a ladder to reach up and connect the mounting arms to the mounting brackets and then to the top piece of the basketball pole. Each of mounting arms has a hole at the end that you need to line up to the mounting bracket and secure with a screw, add a nut and tighten with a wrench.
Line up the holes at the end of the two top arms to the top holes of the top of the basketball pole. Insert the long screw through the holes of the arms and pole, secure it with a nut and tighten it with a wrench. Install the bottom arms to the lower holes of the basketball pole.
I hope the above helps.....
Good luck.
Posted on Apr 03, 2011
alpug
  • 1961 Answers
SOURCE: I need instructions for a
Hello!
You can find the directions from the link below
http://www.docstoc.com/docs/49340452/Height-Adjustable-Basketball-Goal-Assembly---Patent-5738601
Posted on Aug 31, 2011
  • 50270 Answers
SOURCE: How you put together a Huffy 44in basketball goal have no instructions
try Google for a manual
Posted on Jun 04, 2015
I have a Spalding 60 inch glass basketball system. It was lowered all the way down and now it can't be raised because it's too low. How do I fix this?
In-ground Basketball Goals: Spalding 88369 NBA ...
www.atlantahoops.com > In-Ground Basketball Goals
The Spalding 88369 NBA Inground Basketball Goal System includes a 60'W x 36'H Pro style extruded aluminum framed Tempered Glass or Acrylic backboard ... Click here to download the Spalding 88369 Basketball Goal Owner's Manual
Jul 26, 2015 | Spalding 79307 Basketball Backboard and...
I need a instructions on a lifetime portable basketball goal that i can praint out
Here is a link to the manual you are looking for. I found it on the manufacturer's official site.
Jan 29, 2013 | Project Runway Lifetime 48" Portable...
Sport & Outdoor - Others Logo
292 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
