Question about Meiko FV 40.2 Dishwasher
I got error 702 any idea please.. meiko 40.2 dishwasher
we doing washing by hand please any one can help
I have meiko 40.2 under counter dishwasher
5 Suggested Answers
Kitcheneer
  • 11 Answers
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Posted on May 10, 2008
whytfang
  • 170 Answers
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
Posted on May 13, 2009
sclarke7
  • 222 Answers
SOURCE: Help - the screws holding the dishwasher under the
yes remove the baskets and the spray arms and the flowplate assy get the screws and reassmble. good luck
Posted on Sep 10, 2009
heatman101
  • 43501 Answers
SOURCE: The dishwasher is leaking at the bottom of the
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
b.,f
Posted on Sep 29, 2010
I have a Meiko Fv40.2 with two codes coming up, 302 and 325. Can you tell me what the codes mean.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Mar 01, 2017 | Meiko Dishwashers
What is 110 maintenance need meiko dishwasher offenburg d-77652
what is 110 error codes maintenance need meiko dishwasher
B230vap
May 23, 2014 | Meiko Dishwashers
Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
May 19, 2014 | Meiko Dishwashers
Meiko DV80.2 error 307
307 Wash tank level sensor defective (short circuit) Check connection, defective sensor, I/O board defective.
Per service manual.
Apr 03, 2013 | Meiko DV80.2 High Temp Door Type...
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
Meiko dv80.2 message: info 124 we don't know what
you have opned the hood close the hood the error will disapear
Jun 13, 2011 | Meiko DV 80.2 Dishwasher
What temperature does the Meiko FV40.2 operate at please?
1)for washing it will work at 60 deg 2)for final rinse at 85 deg.
Aug 09, 2010 | Meiko FV 40.2 Dishwasher
I need an instruction manual for meiko ecostar 530f dishwasher
Mar 30, 2009 | Meiko DV 80.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Aug 31, 2006 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
531 people viewed this question
Top Meiko Dishwashers Experts
Marvin
Marvin
Dennis Boxerman
ray gallant
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
