Question about Symbol LS1908T Wired Handheld Barcode Scanner
I can't configure LS1908T-1000. Where can i find the set-up page or sth? thanks
How do you lock wireless 2wire router
f your referring with the wireless password
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
check the links out
and if referring about the network key:
2wire wireless network key
The network key is located at the side of the router you will see a barcode on it. It indicated the wireless network key.
If you have questions please let me know. Thanks
May 02, 2011 | 2wire (1000-400108-001) Router
How to take configuration test page in HP businessjet 1000 series printer
Found this in a HP support forum
You'll need to load the entire 'HP LaserJet 1000 Printing Software Solution' so you'll have access to the toolbox. Once you've got the toolbox installed you'll be able to print a configuration page and see the page count.
Here's a link that should get you to the software downloads:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?locale=en_US&pnameOID=45675&taskId=135&prodTypeId=18972&prodSeriesId=45674&submit.y=0&submit.x=0
Original Post:
http://h30499.www3.hp.com/t5/Printers-LaserJet/Laserjet-1000-page-count/m-p/324372
Oct 20, 2010 | HP LaserJet 1000 Printer
Lost installation disc for homeportal 1100.....
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | 2wire (1000-400108-001) Router
(1000-400108-001) Router: Hi. I recently bought a laptop and am trying to wo...
Please open the page of your router. tou can check that address to open in the following way..
Start--run--cmd--ipconfig
Check the default gateway. it will show you like. 192.168.1.1 or 10.0.0.1
put that address in IE and configure the router by your Username and password provided by your ISP. you can call your ISP to configure the settings.
May 05, 2010 | 2wire (1000-400108-001) Router
ROUTER CONFIGURATION
hook computer up to router with the eithernet cable first, then in internet address bar, type 192.168.1.1
Then this will bring you to your router configuration page.
If it does ask you for username and password and you have not set it up yet, then try using
Username: admin
Pass: admin
Jul 27, 2009 | Toshiba WRC-1000 Router (PA3227C1ETC)
My printer 2600n is printer continious pages....
You can restore the printer as factory setting by pressing Left & Right button & restart the printer. Then again configure the printer may be it will work.
Thanks
Sep 08, 2008 | HP Color LaserJet 2600n Printer
Anything is being transfers to PC
Do you test with the notepad of Windows ?
Did you scan the appropriate barcode ?
Sep 02, 2008 | Symbol LS1908T Wired Handheld Barcode...
Getting to the admin page on a Toshiba WRC-1000 wireless router
If that is the DG, then it should get you to the Web Config Tool. But... These devices sometimes come out of the factory with the Web Config Interface turned OFF, so the best you will be able to do is to either Telnet to it, or find the reset switch, which will reset it to the factory default configuration... If you are going to sell it, I would just reset it myself...
From the looks of the features included with this, the reset switch is on the back panel.. Once it is reset, you may even be able to get to the Web Interface again...
DG
Dec 13, 2007 | Toshiba WRC-1000 Router (PA3227C1ETC)
Symbol LS1908T Wired Handheld Barcode Scanner Logo
403 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
