Question about Garmin nuvi 255W GPS Receiver
My garmin 225 W does not power up when plugged in. The unit is only about 1.5 years old. Is there a battery in this unit? If so could it already be bad?
  • Garmin Master
  • 6,993 Answers
yes, there is a battery in the unit. The battery is also obviously the cause of the battery.
Get the battery replaced and problem will be solved.
Take care.
Posted on Jul 21, 2010
My garmin wont go past the loading maps screen and if it does the touch screen wont work please help
Mine is doing the same thing. My Garmin is just about 1 year old now. Wonder if the battery is bad, although I plug it into the power port on my truck only when I'm going to use it.
Nov 18, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
C330 will not power up when plugged into power receptacle in car
First, check the car's power receptacle by plugging in another device that definitely works (or take your gps to another car). Cars generally have a fuse associated with the receptacle that can blow. The second most likely problem is that the internal battery inside the c330 has died. This is especially likely if the unit is old (more than 1 year) and if you live in a climate with extreme heat or cold (which reduces battery life). This video shows how to replace the battery:
The company that produced the video sells a kit which includes the battery and tools necessary to replace the battery yourself. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+STREETPILOT+C330&Show=ExtInfo I swapped the battery of my brother's dying GPS using the aforementioned kit and all went well. His Garmin is back up and running smoothly.
Hope this helps.
Jul 11, 2010 | Garmin StreetPilot C330 GPS Receiver
My Garmin nuvi 250W GPS is NOT powering on.
try connecting it to your computer via the usb cable. that may reset it. outdated maps will not cause this problem.
Feb 21, 2010 | Garmin nuvi 250W GPS Receiver
Battery on my garmin c510 sat nan wount hold a charge how easy is it to change
Had the same problem. Fixed with a new battery. Takes the same as a Streetpilot c530 and can be purchased anywhere on line. A 10 minute job with a soldering iron.
1. Open face plate. Unscrew 4 screws. Remove battery connector and clip.
2. Unsolder the wires to the two speakers - 4 wires.
3. Remove the sticky wrap from the old battery and place around the new one (to stop it rattling).
4. Solder back the new speaker wires.
5. Plug in battery, reassemble unit and charge Garmin off PC wih usb cable.
Done!
Sep 15, 2009 | Garmin StreetPilot C330 GPS Receiver
I get a 'battery missing' indication on my Garmin 478. The battery is in place, I'm on 120v external power and the battery does not indicate that it is cahrging. I have a Log Entry - battery low...
Although the WebUpdater should always be the first stop, the instructions do state that you need to have full charge to ensure you don't "brick" the unit.
I've had the unit about 3 years. I already replaced one battery for this issue. I got the new battery, charged it up, and was happy. Several months later I tried to charge it up again, and got the same "Battery Missing" message. It can't be the battery!
I think it's when the battery is COMPLETELY discharged the battery can't be properly detected. You have 2 choices:
1-Leave the unit on the charger for several hours. It may trickle in enough power to recognize the battery eventually.
2-The other option is NOT AUTHORIZED by Garmin, and you do it at your own risk! Find a 12v car charger you don't need. Expose the wires if necessary. Tape the positive to the contact on the far right of the battery, the negative to the middle, and nothing to the left (that's a data connection). Plug the 12v car charger in, and let it sit for a few minutes, not long or the battery could overheat.
I left it on for under 10 minutes. When I inserted the battery back in the unit, it recognized the battery immediately and happily charged the battery.
Long term, this is probably not an ideal solution. The voltages might not match, there are computer chips in the battery that are designed to receive power the "Garmin" way, and you could severely damage the battery (even explode?).
But if it's this or trashing a $700 unit, it might be worth a try.
Sep 27, 2008 | Garmin GPS
Replace internal battery on garmin gps3
Hi - I have a Garmin GPS 2 plus unit which is around 10 years old. I haven't used it for about 2 years. Initally it powered up and eventually found satellites. I switched it on the following day and it will not power up. I have changed batteries but nothing works - tried a master reset but agin nothing - it appears to be dead ?
Ali
Aug 29, 2008 | Garmin GPS
My Garmin c340 turns on then shuts off even when plugged in
I have the same problem. I have had it for only 4 months.
Jun 23, 2008 | Garmin StreetPilot c340 GPS Receiver
Zumo 550
my battery failed after less than a year of use. Garmin sent me a new battery and the unit is working fine now. The old battery would not provide ANY power to the unit.
Dec 13, 2007 | Garmin zumo 550 GPS Receiver
I have the same problem a another lister, my C330 will not hold a battery charge
Goat feva... Please advise if you discover a resolution for this problem. I'm having the same problem. Unit works just fine while in the cradle but that's it.
Mar 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
224 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
