Hi,anybody has a part# for the tension spring for HP Business Jet 3000 - Tray 2
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details
Thanks for using FixYa.
Posted on Jul 27, 2010
60 02 error
Hi
I had the same problem on a customers 4250 and here is my solution.
It appears that the spring which holds the lifter motor upright was designed
without enough tension on it.
If the spring is removed and the motor assembly is allowed to fall to the
right when the paper tray is inserted the motor never engages the tray
and a 60.02 error appears. However if the motor assembly is held upright
while the tray is inserted the error message never appears as the motor
always engages.
I have found that a spring from a laserjet 4v toner cartridge is the same length
and shape but utilizes a heavier gauge steel.
When I used this spring in place of the OEM spring the 60.02 error message never appeared again.
Jan 12, 2011 | Office Equipment & Supplies
Have a problem paper tray will not go back in printer on 1320
Flip the tray over, there is a little pawl there that locks it down to insert it (In the center, near the front), it is held in place by a spring and often that spring pops out.
Nov 19, 2010 | HP Laser Jet 1320 Printer
YTS 3000 clutch return spring noise, sounds like it is rubbing on something when you release the clutch but I can't even find the spring
The spring will be attached to the tensioner pully right on top, there is a threaded bolt with nut holding the spring on, I just had to order the clutch cable because the spring broke, from rubbing on metal when engaging and disengaging the clutch lever.
Jul 30, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
How do I change tray settings from tray 1 to tray 2?
Browse through the menu's of the printer
Paper Handling Menu, Set
Tray 1: Any size / Any Type.
Tray 2: A4 Size / Plain Type.
This should solve the issue
Regards,
Nikhil
Jul 10, 2009 | HP LaserJet 2420 Printer
HP Photosmarty D7360 - spring on paper tray broke
This is possible but hard to explain in writing, best thing to do is go back to the store and hope that they will be able to do it for you as a service.
Jan 03, 2009 | HP Photosmart D7160 InkJet Printer
Hp2100 laser jet printer
Its tray spring to be check, whether they are inclined or not. Sometime it does not lift the tray up to catch paper by printer. I often get the problem and can be solved easily.
Let me know if you need further assistance.
Oct 06, 2008 | HP LaserJet 2100 Printer
HP Business Inkjet 2800 - A3 Problem
Separate the Tray 2, on tray2, u would c couple of while rollers.. check how do they roll and clean for any dust.. While rolling if u feel any friction or any of the rollers broken.., then u need to replace tray 2.
Jul 15, 2008 | HP Business InkJet 2800 Printer
Error 13.20.00
There is a paper feed sensor located behind Tray 1 where the tension spring gets knocked loose, therefore the sensor arm is still blocking the sensor. You have to remove all covers and the Tray 1 Assembly and re-install the spring which goes into a slot on the plastic frame.
Apr 11, 2008 | HP LaserJet 4350 Printer
14 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
