Question about Casio QV-R40 Digital Camera
Will not do anything
I turned my camera on one time and the lens opened but it would not do anything. I have changed batteries several times so I know it is not the power source. Now my lens is opened and the camera is completely dead. It is a Casio QV-R40 4.0 Mega Pixel. What is wrong with it?
    Problem Solver:
  • 7 Answers
When I turn the camera on, the lens goes in and out several times. Then the message comes "turn the power off and on again". I tried taking the battery out, pressing the power button for 15 sec...
Hi there this is Lens guide pin problem. 99% chacHi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated e is replacing the lens. but before that try these below.
Feb 01, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
My old FM2 shutter is stuck open. Batteries and shutterspeed have been changed but it doesn't work. IS it an econmic repair?
With the new batteries installed, try to hold your camera with your right hand with the lens facing down. Then try to turn turn on the camera while hitting the base on your left palm. Do this several times until the lens retracts.
This might caused by sand or granule of dust stucked on the side of the lens, not forcing it to retract.
Sep 21, 2009 | Nikon FM2N 35mm SLR Camera
The lens will not open all the way when the camera
You may have a LENS ERROR.. Please search "LENS ERROR"
Aug 19, 2017 | Nikon Coolpix 2100 Digital Camera
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Jul 26, 2017 | Konica Minolta Zoom 160C Date 35mm Point...
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Lens error displayed by coolpix 3700
With the lens facing downward, hit the camera a sharp tap against the palm of the hand whilst simultaneously turning the camera 'ON'. If that fails, tap against a stiffer surface (desk or table), allowing room for the lens to extend and taking care not to damage the body of the camera.
Oct 08, 2007 | Nikon Coolpix 3700 Digital Camera
Casio QV-R40 Digital Camera Logo
108 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
