Question about Maytag Neptune MAH5500B Front Load Washer
Cotton/sturdy button not working on the select fabric
My cotton/sturdy button is not working, however all other select fabric button are working properly.
"I have the maytag neptune mah5500bww. the cotton/sturdy button" it has an led read out.
Posted on Aug 02, 2010
Where can I find good quality fabric at cheap rates?
Well, there are many online stores where you can find good quality fabrics at affordable rates. But if you are asking me then I would personally suggest you to buy from tulle fabric store as they have different varieties of fabrics which are good in quality and even you can also find other accessories like shawls, scarf, etc. You can also get cotton fabric at an affordable rate but like other stores provide bad quality fabrics, here you can get all the latest designer fabrics at a price which will fit your budget easily.
Jun 06, 2018 | Washing Machines
How to fix guiding arm to Janome DXL603 walking foot & what thickness cotton and needle are best? Top tension? Cotton fabrics & 2mm wadding used.
This is a tutorial for sewing 1/4" seam on a quilt sandwich but also shows how to install the walking foot:
http://www.janomespecials.com/mc11kse/video/even-feed-quarter-inch.html
As for tension, etc., you would test and adjust on a scrap sandwich made of the same material as your project. The top and bobbin threads should meet in the middle of the sandwich. Your machine also has an adjustable foot pressure. If you are sewing a thick sandwich you may need to lighten the pressure so the sandwich will feed easier through the machine.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjwhPW03I3ZAhVE3GMKHQg0D9oQFgidATAC&url=http%3A%2F%2Fwww.strima.com%2Ftv%2FJanome-DXL603-QXL605-Strima.pdf&usg=AOvVaw2S97hWN8Ku6uliH260S9Qc
More tutorials
How to Videos Janome
Here's information about needles. For quilting sandwiches (with woven cotton, not knits), use a "brand new" sharp needle (like a universal, top-stitch, embroidery, or quilting needle) of the size large enough to accommodate the thread you are using and sturdy enough to be able to penetrate the sandwich without bending, probably at least an 80/12 or larger but not so large as to leave holes in the quilt.
https://www.schmetzneedles.com/all-about-needles/
Thread really depends on what you and your machine like to use. You can use cotton or polyester. Just be sure to use a good quality thread--nothing that has been setting in the drawer for 5 years or that was purchased from the bargain bin.
Feb 05, 2018 | Janome Sewing Machines
Where can I find women's raincoat fabrics?
There are many online stores available where you can find raincoat fabrics for women. One of the best online store which I like to suggest and that is silk lace fabrics. Here you can find raincoat fabrics as well others fabrics like silk fabrics, cotton fabrics etc. at a very reasonable price.
Dec 06, 2017 | Sewing Machines
How can I get a shorter wash on the Logixx7. Every wash is lasting at least 3hrs!!!!!!!!.
Hi dear,
I do not know what type or model of your washer but those LOGIXX series should have a INTENSIVE wash button. Make sure that button not active when you setting your program by default and you are not over loading your machine. You need to use specific program for specific wash load. Example: Let's say your machine has 7Kg dry weight wash capacity. That's indication for Cotton Fabric Only. Your machine able to wash 7Kg Cotton fabric but it can not able to wash 7Kg WOOL, Dedicates, Jeans etc. Refer your machine's user manual. I hope that helps. Thanks.
Jan 31, 2016 | Bosch Washing Machines
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
HOW DO I GET INK STAINS OUT OF A WHITE COTTON SHIRT?
Rubbing alcohol or methylated spirits (denatured alcohol) from the drugstore or hardware store are ideal to remove ink stains, as long as the stains have not set. The alcohol neutralizes the pigment in the ink so it disappears. Either soak a washable garment in rubbing alcohol or methylated spirits, then wash as normal,[2] or use the following process:
  • Dip a clean cotton swab into rubbing alcohol.
  • Dab at the soaked up ink mark with the cotton swab (bud) or small sponge.
  • Repeat this each time with a fresh cotton swab or sponge, as many times as needed.
  • Dip another fresh cotton swab or sponge into cold water and dab the area to remove the alcohol from the fabric. For best results, let the fabric dry before trying to remove the ink stains again. Rubbing alcohol works best on a dry fabric, but after each application you must rinse it with water. The process of removing heavy ink stains is a lengthy, cyclical process of blot, rinse and dry.
  • Allow the area to dry. Wash the garment as normal.
cheers
Mar 03, 2015 | Dryers
What would a typical tension number be for a cotton fabric? mine is loopy or tight right now
you didn't mention the name and model number of the sewing machine or serger... is the loopy thread on top or bottom? when is the thread tight? what type of cotton fabric,, solid cotton--polyster cotton? normally mine stays on 4 or 5 --depends on fabric I'm sewing..
Dec 15, 2014 | Sewing Machines
How to change the wash time on the washer. It runs for 99 minutes now?
The drain system may have a coin or similar item obstructing the flow. The pump has three impellers and one could be missing. Check the boot. Squeeze it and dump any objects in it out. Also the screens in the supply hoses may be partly plugged. The drain hose may have something in it. Make sure nothing is in it. If these things are okay, live with it.
Sep 19, 2014 | Maytag Neptune MAH5500B Front Load Washer
How to set singer machine for strechy fabric
Hello, Most often if the machine sews fine on a regular material, cotton, denim, ect.....then the material...in this case "stretchy" is moving up and down with the needle...this is called "flagging" the material moves ever so slightly and this cause the hoop that the hook would pick up to be either not the right size or just a fraction out of line with the travel of the hook. On most industrial machines you can increase the presser foot pressure and cure it. From time to time the size of the hole in the middle of the presser foot can allow movement... so you might try applying a sturdy tape or material to the under side of the foot in order to reduce the hole side.
Hope this helps!!
Sep 02, 2014 | Singer Sewing Machines
Janome machine probs
try a ballpoint or a stretch stitch needle, that what I use when sewing
knit, t-shirt. it doesn't break the fiber in the fabric.
Jun 05, 2012 | Sewing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
