Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Beater Bar stopping and making noise
My Dyson DC14 vacuums very well. However, while vacuuming the beater bar will stop turning or turn slowly and the vacuum will make a horrible noise followed by a burning rubber smell. I've cleaned the beater bar thoroughly and looked to see if something was jamming the belt but can't see in there very well to really know for sure. I can't seem to figure out how to take the vacuum apart so I can look at where the belt connects inside. Please help with this problem and for how the vacuum opens up. Thanks.
  • milehighdad6 Jul 19, 2010
    Unfortunately, I don't have a lot of time and this problem couldn't have come at a worse time. We have a wedding at the end of this week and many people coming in so being without a vacuum compounds our "getting ready" problem. Has this problem ever come up before and what was the solution/outcome? Is there is a schematic for how the Dyson comes apart?
  • milehighdad6 Jul 20, 2010
    I have gotten some good advice as far as cleaning the beater bar but now that I've thoroughly cleaned the beater bar and removed hair from the other end of the belt ... but was unable to remove the belt as the vacuum would not come apart, the beater bar is very tight while attached to the belt and will not turn at all. The beater bar by itself moves very freely and smoothly. So far, I do not have a functioning vacuum. Thanks.
  • 435 Answers
Hello, I noticed this request for help has come up before, It's almost impossible to discribe what you're needing to do. Your model has 2 belts, 1 from the motor to the clutch and 1 from the clutch to the beater bar. There is a special tool to hold the belt in a position that the beater bar can be re installed, but with a little patience and maybe another set of hands it could be done with 2 screw drivers.
Go to this link and the video will show you step by step how to dis-assemble your vacuum so you can service the belts and or clutch.
http://www.youtube.com/watch?v=7_CtaFcc5HU
Posted on Jul 20, 2010
    Genius:
  • 1,040 Answers
Hi
Following links may help you...
http://www.ehow.com/how_6174789_fix-dyson-dc14.html
http://www.ehow.com/search.aspx?s=dyson+DC+14&Options=0&x=0&y=0
Hope this links has helped you... thanks..
Posted on Jul 19, 2010
  • 677 Answers
I have a dyson...call them..they are very good when it comes to customer service. they shipped out a part to me fed ex and I had it the next day.
They will assist you on how to remove the part you want to remove.
Take care.
  • 2 more comments
  • ikechukwu joshua
    ikechukwu joshua Jul 19, 2010
    After reading a ton of forums I thought it was the clutch assembly. Got a
    new one on eBay for a great price. Somewhat hard to replace, but thanks
    to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-c...
    HOWEVER this did not resolve the issue. I realized the beater bar was
    not spinning or was slipping. I thought I cleaned it all out but
    realized you need to take it apart and pop the end cap out and clean the
    INSIDE of the beater bar. I additionally sprayed WD40 in there.
    It spins great now and in the end I think that's all I had to do was
    clean out the cat hair build up inside the beater bar. But now I have a
    new clutch & belts too. Hopefully won't have issues anytime soon.
    I had the same problem with my DC14 that was only months old. What
    I found was the beater bar was covered with hair. I removed the cover
    and cut out the hair as the owner’s manual said. That did not solve the
    problem.
    After further investigation I found that the belt was tracking to one
    side, there was hair under it. I cleaned that hair and also found out
    that on each side of the belt chamber there are small protrusions that
    ride on the beater bar. The bar was not centered over them and they were
    causing the clutch to slip. Once I positioned the bar
    correctly and removed the hair from under the belt all worked
    wonderfully.
    Moral of the story, clean the hair from the brush and under the belt and
    make sure the bar is positioned in the vacuum properly and turns
    easily.
    What I found was that it is the roller brush. If you are willing to get
    a little dirty and do it yourself, there is the roller brush that most
    likely needs to be cleaned. After a little tinkering of my own, the
    roller brush can be slipped out or just shift it out of place to clean
    it. There are two ends to the roller brush and the brush itself. Of you
    twist the two ends until the come apart you would probably find a lot
    of hair and other long strand items wrapped around the rod that goes
    through the brush. Once you clean that out it should work like new. If
    that does not work then it is probably the clutch which is what the
    belt around the roller brush is connected to. Hope this helps, it is a
    simple solution.
    If you've taken off the plastic cover part to fully inspect the bar and there are no peices of dental floss or anything else that may be causing an obstruction, you might have to get a new one.
  • ikechukwu joshua
    Hi, Am sorry,the schematic diagram is not yet available, I think you still have to use the above link to contact DC14 vacuum service center for help. Please the rating was not necessary.
    Take care.
    Thanks! I got the beater bar ends off and yes there was hair wrapped around the internal pin. That's all clean but once I put it back together, it still makes a terrible sound and the beater doesn't even attempt to turn. I was able to take a lot of components off and can now see with a flashlight that there is hair wrapped around the other end where the belt connects. I cannot get the plastic housing off the belt assembly. I'm a bit afraid of just trying to "pop" things off because I don't want to break them. One part that I'm pretty sure needs to come off is the knob that you turn to carpet or bare floors. I could use advice on that. Thanks.
    Now that the beater bar is completely clean and I've removed hair from the other end of the belt, the beater bar, when reattached, is much tighter. When I turn on the vacuum, the belt does not turn at all.
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Fault finding
Have you accidentally switched off the beater bar via the dial on the head? Some models have a 'hard floors' and a 'carpets' setting (which disengages/engages the beater bar).
Jul 06, 2014 | Dyson Vacuums
The beater bar is not turning. While vacuuming, it made a harsh noise. I turned it off, unplugged it and took off the beater bar cover. I cleaned it and cut the hair off the beater, but the belt feels...
I'm sorry to hear you're having difficulties with your DC14 Animal. The brush control system is designed to make a ratcheting noise to warn you if something jams the brushbar. To ensure everything is correct with your machine, please follow the quick troubleshooting checks shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=668&product=DC14-ANIMAL
Please note, the brushbar will never rotate when the cleaner is standing upright, or if you have the brush control set to 'Hard Floors'.
This should allow you to resolve your issue without further assistance. However, if you've followed the steps shown in the support guide and are still concerned, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you to establish the cause of the issue, and will be able to recommend the best course of action.
Kind regards,
Jack
Dyson Online Customer Support
Sep 07, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
We have a dyson dc14 and the beater bar stopped turning, we cleaned the bar off and checked the belt and it's not broken, I know I called Dyson a year or two ago and they told me how to reset the beater...
Hi its Darran at Dyson.
Check that the brush control dial is in the centre position when the machine is locked upright. When you release the head and pull the handle back this dial should mopve forward to the on position. Once here, the brush bar should turn.
If this doesnt resolve the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Mar 31, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beater bar on my Dyson DC14 All Floors Bagles vacuum cleaner doesn't turn. There is no hair or thread caught up in it. All air-flow areas have been checked and there are no blockages that we could...
If it is not on the bare floor setting then you most likely have a belt issue it is not an easy fix I am sorry to say if your mechanically inclined I can tell you how to replace it.
Dec 17, 2009 | Dyson DC14 All floors Bagless Upright...
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Mar 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
243 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
