Question about Bauknecht 24 in. GSF8984 Free-standing Dishwasher
F1 error dishwasser Bauknecht GSF 4862
Can anybody please help me with my defect dishwasser.
I have a Bauknecht GSF 4862 dishwasser and erverytime i turn the thing on it presents an error F1 on the display folowed by stopping his program.
I want to look for a constipation in the water hose, but i don;t know how to do that
How can I solve this??
3 Suggested Answers
  • 641 Answers
SOURCE: What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Posted on Jul 26, 2007
caroldon
  • 17130 Answers
SOURCE: My Bauknecht GSF 6550 dishwasher
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect. The error indication can be a short in the circuit, check the heater circuit and the pump motor.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Posted on Sep 03, 2011
What does F1 means GSF 7497?
Google it MAKE plus error number
Sep 29, 2017 | Washing Machines
Bauknecht gsf 4481
The timer is not advancing to the next cycle. Replace the timer.
Mar 13, 2014 | Bauknecht Dishwashers
My Bauknecht GSF 6550 dishwasher is stuck with error F4. Whar does it mean ? What can I do?
Sep 03, 2011 | Bauknecht 24 in. GSF8984 Free-standing...
Have a Frigidaire FEF353bfwc. Getting error message F1 and start button lights up and beeps constantly. What to do? Can it be fixed? and what would you guess is approximate cost?
Hello there and thank you for choosing fixya
The dreaded F1 error code can be difficult to diagnose but here is the best thing to do
this is from the manufacture of the oven.
F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Aug 05, 2011 | Ovens
What is an F1 error?
On Magic Chef ranges, F1 usually indicated a defect in either the keypad or the electronic control. If the error shows when the keypad is disconnected from control, the problem is usually in the control. If the error ceases with the keypad disconnected, the keypad is usually the cause.
On some models the keypad and electronic control are 1 integral part in which case the whole control assembly usually has to be replaced to correct the problem.
ok i hope this is very helpful for you please post me a comment and i can help if you need assistance with parts support or disassembley ok
Best regards Michael
Feb 27, 2011 | Magic Chef Ovens
I have bauknecht cloth washing machine,is written in Germany so i can not operate it,i need english,model wt9640
You will need to go on-line I suspect.
Type in 'bauknecht washer manual' into your search engine and you should be presented with sources from where you can download for free or have to pay.
Good luck,
John C
Feb 10, 2011 | Washing Machines
Maintenance lights won't go away
elaine hopefully this will help. advance your selector dial to the 6 o'clock position, press start 3x. advance your selector dial to 7 o'clock position, press start 3x. turn the unit off then on. try using it as normal.
Apr 24, 2017 | Whirlpool Dryers
Bauchnecht GSF 5343 dishwasher
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
May 04, 2008 | Dishwashers
Bauknecht 24 in. GSF8984 Free-standing Dishwasher Logo
210 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Carmen Mikulic
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
