Question about Frigidaire Dryers
Affinity aeq6000es2. After two cycles of the
Affinity aeq6000es2. After two cycles of the clothes not being dried, my husband turned on the dryer than looked behind it. As this was happening, large sparks starting shooting off in the drum and making loud cracking noises. There was only one shirt in the dryer that did have metal snaps on it. I do not want to turn it back on. Do you know what would cause little heat and then sparks?
  • kraz4ba Jul 19, 2010
    We replaced the heating coil but it happened again. Any advise?
    President:
  • 2,468 Answers
Sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Posted on Jul 19, 2010
Testimonial: "Exactly what my husband thought. Thank you so much."
SOURCE:
My dryer (Frigidaire Affinity)just stopped working as if the power shut off.. I have checked the breaker, it's fine. it stopped in the middle of a drying cycle. I'm thinking the control panel went out
http://www.appliancepartspros.com/repair-help/frigidaire-dryer-aeq6000es2-repair/aeq6000es2-wont-start.html
Take a look at this web page/video. Your problem may be that the thermal limiter switch blew (which is not that easy to replace) .... compared to something in the control panel going out. Had you been doing a lot of heavy dryer loads before the unit died .. or a lot of lint built up? A blown limiter switch in some dryers will be as if you unplugged it (nothing goes on) ... but some dryers will still turn the drum but not heat. I am not sure about your unit.
The limiter switch is a safety device so your dryer does not overheat .... so if the switch did blow try to understand WHY .... or it may just blow again.
Good luck...
Jan 02, 2018 | Dryers
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Takes 3 cycles to dry clothes even on towel cycle
If the clothes are hot when they come out but moist or damp it mean the moisture is not getting vented, Check your vent pipe for blockages or leaks.
Apr 30, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Open Questions:
Frigidaire faqe7011lw0 dryer having issues, not heating up and shuts off after 10 minutes My dryer model number is faqe7011lw0. It seems to start up, and then after about 10 minutes, consistently, it shuts off and has a bunch of blinking lights on the right side of the control panel. It started off with an error code of E4A which states "The drying time has exceeded program time for that cycle". I got that code to go away and then i got another code of "E4B" which states "Temperature reading of control thermistor has not changed in a certain amount of time". The second error code makes more sense because I notice in the 10 minutes that it runs, there seems to be no heat, so i feel something is causing the dryer to not heat up. The troubleshooting for this states to test a relay on the control panel, but I wanted to see if anyone else had this issue before. The weird thing about this is, if I run the dryer empty, the cycle completes the whole way through, but with wet clothes, it shuts off exactly at 10 minutes, no matter what cycle i set it to. I thought maybe this was a sign I had too large of a load in, so I took out about half the clothes, and ran it then. I still got the same issue. So I am kind of confused why when I run it empty, I get the full cycle with no error code, but with anything in the dryer at all, it stops after 10 minutes and gives me an error code. FYI, I have check the exhaust too to make sure it isn't clogged with lint, and it is wide open.
Mar 18, 2019 | Frigidaire Dryers
Dryers Logo
361 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
