Plugging a turntable into a harmankardon 147 receiver: where and how to get volume. The sound volume is too low.
    Scholar:
  • 54 Answers
The 147 receiver doesnt have an input for a turntable. THe output from a turntable is VERY low and is heavily equalized because of the actual record format ( the bass is cut way down and the highs are boosted.....when run through an actual phono input, it "un does" the equalization by boosting the bass and cutting the treble......this is called the RIAA compensation curve ).
You need wither a receiver with an actual phono input, or a good quality Phono Pre Amp....
Good luck... Rob
Posted on Apr 22, 2008
I just purchased a used Sony turntable PS LX 160H & am hooking it u Sony surround sound amp (there is no phono input but am using audio input) and getting sound but very low volume at max volume... How...
Just look around the web for a "Magnetic Cartridge Preamp".
You plug your turntable into this and the preamp in an aux socket of Surround Amp and the sound will be the same level as the other devices.
Sep 05, 2010 | Sony PS-LX250 Turntable
I recently aquired a used rotel rx102 stereo receiver and onkyo cp101 A turntable. I bought a new stylus needle for my turntable, and plugged the turntable into the phono jacks on the receiver and from...
If the receiver doesn't have a function specifically named PHONO, yes. Very few AVR's have phono preamps. They're not expensive. I'd check eBay.
Jul 05, 2010 | Nakamichi AV-7 Receiver
I just hooked up my husband's turntable to our stereo receiver and the volume is very low. Is that inherent in the unit, or am I missing something?
You need to make sure that you plug it into the receiver with PHONO input.
New receivers today does not have PHONO stage so the sound will be very very low and not listenable at all.
what model is your receiver?
Jun 18, 2010 | Sony PS-LX300USB Turntable
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
Phono plays lower in volume than cd and tuner. Sounds ok i guess but is about a quarter to one third lower in volume. Is this normal ? Can I plug phono into cd jacks to check if any better ?
Hello. As per the post before me, if you have a receiver with a Phono input(many receivers don't have one anymore) the output of a phono cartridge is around 30 millivolts, vs 300 millivolts for a CD(10 times the amount) or any other line level device. A Phono preamp, also has RIAA(recording engineering standards)Equalization that provides the proper equalization for a Phono cartridge. As per the other post, yes, it will sound very low, and unnatural sounding. If the input you are plugging the turntable input into, doesn't say Phono, you can purchase an inexpensive Phono preamp made just for this very issue. You can try Radio Shack, or find something of better quality on the Internet.
Regards,
Dave
Jan 11, 2010 | Pioneer VSX-453 Receiver
ION turntable volume is low when plugged into a receiver.
Either the cartridge has failed, or an internal amp in the record deck has, or despite what you say the receiver has. I will clarify this for you. Magnetic cartridges need a pre-amp before it gets amplified by the pre-amp and power amp of your reciever. If that pre-amp fails you will still hear the low sound from the deck, but all others cd/tape would be normal as they don't go into the deck pre-amp.
All you need to is trace the circuit. Find the magnetic cartridge pre-amp and find where it joins with the pre-amp of the amp! If you stick a screwdriver at that point, you will get a buzz at normal volume on each channel. The cartridge pre-amp has gone if you do get a buzz!
You probably find it's a single IC that's gone, some are prone to static problems.
Jan 01, 2010 | ION Audio iTTUSB Turntable
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
Turntable problem
It could be a couple of different things.
Do you get any sound, even very faint, if volume is turned up all the way?
If so, you probably have the turntable connected to the wrong type of input or you have the wrong type of turntable for the type of input you have on the receiver.
Older turntables have a very, very low level of audio output which requires an input that has much more gain than the normal type of audio input on a receiver.
Many newer turntables and receivers has the same level phono inputs and outputs as the other inputs and outputs of the receiver like the CD or Tape I/O. When an older turntable with such a low level output is connected to this type of phono input the sound is so low you can only hear it very faintly with the volume all the way up.
If you have the proper type of turntable for the type of input on your receiver, then the problem is most likely in the turntable. To check if it is or not, disconnect the turntable from the receiver, and then connect an RCA cable to the receivers phono input with nothing connected to the other end. Then with the volume turned up just about 1/4 to 1/2 the way up, touch the ends of the male ends of the RCA cable that are not connected to anything with your finger lightly tapping it a few times. You should be able to hear the tapping sound real easy in the speakers. If you hear that noise you know that the receiver is OK. If you don't hear anything the receiver has a pre-amp problem or the receiver is not set to the proper function.
If you determain the receiver is working normal, you have a problem in the turntable. Most times it is the stylus or the wires connected to the cartridge which holds the stylus.
Another thing to check is that if your turntable has a ground wire coming off the back of it near the RCA outputs of it, make sure that it is connected to the chassis of the receiver. Most receivers have a ground terminal right on the back that you can loosen with your fingers and then put the ground wire from the turntable in there and tighten it hand tight. If it has no ground terminal on the receiver you can always just loosen a screw on the back and connect it there. Make sure the ground wire has the insulation cut back to expose the bare metal, that insures that you have continuity from the ground of the turntable to the ground of the receiver.
If your turntable has no ground wire, then you have a newer turntable type that would be able to plug into any of the audio inputs on the back of the receiver. It would be a turntable with a boosted signal that can only be connected to an input with the same level as the CD or Tape input.
I hope this helps you to figure out what your problem is, if you need more help don't hesitate to reply to this post. I will get back to you as soon as I am able.
If this was helpful for you a "FixYa!" rating would be appropriate and very much appreciated, after all, it is the only reward we get for helping people like yourself for free.
Thanks,
Dave
Sep 06, 2008 | Yamaha RX-V995 Receiver
Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Mar 02, 2008 | Audio Players & Recorders
123 people viewed this question
 Grubhead
Grubhead
