Savin C2525 Is getting a c548 error, I looked it up and its is a fuser installation error? If it is how can I reset the code and fix the fuser?? Thanks
  • 19,396 Answers
C548 is not "incorrect fuser installation error", but " Fusing unit rotation error". This is caused by the fusing belt sensor not detecting any change in the actuator after the fusing/paper exit motor has turned on.
The sensor is the position sensor for the fusing belt, located on the left side of the machine (where you have controls).
The reset is done pressing the yellow reset key. If that does not clear the error try disconnecting power, restart, and reset again. If still no luck, the error is caused by toner on sensor, or by a faulty sensor.
Clean toner from belt and fuser assembly, if that does not work, replace the fusing belt sensor or actuator. If still no luck, replace whole fuser assembly.The job should be done by a technician.
Posted on Jul 19, 2010
I have a Savin 8035e. I had an error code SC542 and reset the copier as suggested. Worked great. Problem now - How do I fix alignment?
That error code is a dirty fuser thermistor. Clean it and go into service mode then turn off main power switch. That is all that is required. What is out of alignment?
Oct 10, 2014 | Savin Office Equipment & Supplies
How do I fix error code sc 548?
SC548: Fusing unit installation error -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
Possible causes:
Fusing unit is not installed
Poor fusing unit connection
Check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of position. SC 548 usually happens when a paper jam occurs and user does not properly fit the fuser back in place
The fuser may also not be fiitted properly due to some foreign object in between fusing belt and the sensor
From the panel, enter SP 5810 (SC code reset), select "Execute", select "close", exit SP mode then turn main power switch off, wait 30 seconds, the turn it back on.
To enter SP mode, press the yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button. from the menu select copier SP then type in 5801 and press # select execute then power off and back on. Your machine should now be working.
Hope this helps.
Sep 04, 2014 | Savin Office Equipment & Supplies
Im getting magenta backround on all color copies. I replaced the drum and developer, this did not change the problem
I had the same issue. I removed all the drums and DV units, removed the transfer belt and open the manual infrrd door and pulled to fuser. I found huge piles of magenta tone all over the place. Cleaned it up, put it back together and runs like a champ
Feb 08, 2013 | Savin Transfer Belt for C4540, C3535,...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
I have a Savin 9955DP/9965DP copier with a funtional service code SC548-00 is there anything i can do to fix the problem?
The SC 548 error usually occcurs in the fuser section when it ahas been reset incorrectly the drive and gears are not locking properly or the sensor has not registered the fuser correctly I would look in these areas check the seating of the fuser you can reset this in the modes with 5-810 sc reset then turn off.
Jun 24, 2009 | Ricoh Aficio 450 Copier
They code from the display is 0-02H what is the meaning and what is the solution of that?
You haven't included the model number, but it looks to me like a "Ricoh" error code (or possibly Savin / Gestetner which are the same)
Error 02-02H is a fuser error, and is either the heater lamp, fuse or thermistor, causing the "warm up error". This can only be reset by a needlessly over-complicated procedure in service mode once the trouble is fixed.
May 04, 2009 | Office Equipment & Supplies
Savin C3030
SC 553 is a fuser overheat error. If you have a fuser great, but you will still have to reset the code. Clear modes, 1, 0 ,7, press and hold clear/stop key. Menu will change, select copy sp. From there, select 5, (mode), scroll till you get to 5810. Select it, and press execute, then exit back to copy sp. Select 7 (data log) then scroll until you get to 7807. Select it, and press execute. Exit all of the way out, and recycle the power.
If it comes to ready, great. Try it. If it codes out again, you have a problem, possibly thermisters, (in the fuser), power supply getting stuck on, I/O board not regulating the power supply. Could be any of these things.
But start by resetting the code. Could be a a thermister got some toner stuck under it, and the other thermister detected a difference. It really could be that easy.
Mar 12, 2008 | Ricoh Aficio AP3800C Laser Printer
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
77 people viewed this question
jasbo
jasbo
