Question about Samsung HCM4215W 42" Rear Projection Television
Hdtv progressive samsung make a humming noise , but not through the speaker,,,,anoying any ideas
  • Samsung Master
  • 610 Answers
There are several possibilities: a bad cooling fan, color wheel beginning to fail, or a transformer on the power supply board. I would recommend calling a technician to find out which part is failing. You can call 1-800-samsung to find the nearest service center.
Posted on Jul 19, 2010
When playing a DVD on my Panasonic DVD player there is a humming noise which changes pitch each time the scene changes, very anoying, any ideas what to do to stop hum?
tried with other cable connectors that you have been hooked up in the input of the tv. by the way have you been already tried to play with other dvd disc?.
Nov 02, 2012 | Panasonic DVD-S29 DVD Player
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Have a Hum in the sound of the TV
If you mean there's a hum from the speakers it could be a disturbance in your AC line. Or a hum from a DLP projection TV could also be a bad color wheel. But if its from the speakers of the TV it could be noise in the power supply from a few warped capacitors.
http://tvtechwork.webs.com/
Nov 13, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Jul 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
I have a humming noise coming from my new 50in panasonic plasma tv. Is this a common problem and if so what could I do about it? Thank you for your time. Pat
The humming noise should be verry low . It is caused by the powersupply and switching fets on the boards. A plasma screen always produce some sort of humming noise when listen carefully to the device but it shouln't be anoying when enyoing a movie. So it is a natural thing but again it should not be noticable, enyoing a movie at apr. 3 meters or so...
Jul 09, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
MY NEW SAMSUNG LN32A550 TV HAS A HUM FROM THE SPEAKERS
In most cases it's the Cable issue. Either bad Cable Box or the Wires are not grounded properly. Disconnect the Audio Cables or the COAX cable from the Cable Box and see if the Humming noise goes away.
Jan 31, 2009 | Samsung LN32A550 32 in. LCD TV
Tv hums when hdmi is connected via dvd player
how do you have the audio hooked up for it if you are using componet cable (red,white) for sound they could be causing the humming you can either switch audio cables or use some other form of cable for sound
Jan 24, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Dec 11, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung HCM4215W 42" Rear Projection Television Logo
255 people viewed this question
Jerry Greenberg
Jerry Greenberg
